Hydraulic QA Coupler Sizing Questions
   / Hydraulic QA Coupler Sizing Questions #1
Porchfan
Oak Ridge, NC
2013 Kubota B2650 HSD, 2020 BX2380, JD LX-277 lawn tractor 2000
Hey Everyone.
I recently had a 3rd function remote added to my B2650. I want to replace the capped ends of the lines at the bracket the dealer put on with a couple QA couplers in place of the caps.
The dealer (or kit) put/had female to female nipple/adapter at the bracket on each line that is two different sizes. The end towards the valve is a bigger size then the capped end size. The valve side of the nipple is ~0.75. The implement end of the nipple is ~ 0.675.
QUESTIONS:
(1) What's the deal with that?
(2) What size QA coupler do I get on the implement end. I think I'll go with male QA ends.
Here are pics of both measurements
   / Hydraulic QA Coupler Sizing Questions #2
Thats just an adapter fitting.
Looks like a NPT to JIC bulkhead fitting. 3/8" NPT to 1/2 (-08) JIC fitting
Male Pipe (NPTF) x SAE 37° Flare (JIC) Bulkhead
You need fittings with 3/8 NPT to connect onto where the cap is.
And it appears they used teflon tape. Get rid of that and use a sealant or paste
   / Hydraulic QA Coupler Sizing Questions #3
Before you install MALE ends, do a little checking. I am no expert, but virtually all the remotes I have seen had female couplers. 3/8" hydraulic lines are likely the size of most implements you would use with that tractor.
   / Hydraulic QA Coupler Sizing Questions #5
Are you talking about using a coupler in place of a cap? Won't that leave the line open? Maybe I misunderstand you?
Jim
   / Hydraulic QA Coupler Sizing Questions #6
   / Hydraulic QA Coupler Sizing Questions #7
:thumbsup::thumbsup: (All 10 :)) Use one male & one female on the bracket, and one of each on the hoses, so they'll go together correctly every time you connect.
M and F Q-D couplers will seal when disconnected. (as best they can)
There seems to be 'micro-beads' in everything from toothpaste to laundry detergent these days. If there are any in your Teflon pipe dope they'll likely end up in your hydro filter. A worked-loose scrap of Teflon tape will as likely find a more troublesome place to go to.
   / Hydraulic QA Coupler Sizing Questions #8
I have, and often see, a pair of female couplers, so that no matter what you are hooking up, you can get the flow path you want. But in a perfect world, the male and female would also be fine. Leaking shouldn't be an issue.
   / Hydraulic QA Coupler Sizing Questions #9
Why would you need any sealant of any kind on a hydraulic fitting? Is that due to some flaw in the NPT threads? We use BSP,JIC,ORFS and Metric fitting and none of them require any extra sealing.
There seems to be 2 schools of thought on this; most Ag equipment have all 1/2" female couplings on the tractor and male on the implements. This is also how the factory rear remotes are delivered on (newer?) Kubotas. But a lot of CUTs have 3/8" couplings and most of those seem to use the one male/one female principle for each circuit. At least thats how all my Kubotas has been delivered, a 20-year model span.
I have decided to use the first method in the rear and the second for everything up front. That way I can borrow 3pt equipment from farmers around me, and still stay "CUT standard" for FEL and front mount equipment.
/Marcus
   / Hydraulic QA Coupler Sizing Questions #10
Npt requires sealant. Jic and o-ring fittings do not.
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2020 MACK P164T (A58214)
2020 MACK P164T...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
CASE 610 Sprayer System 2000 Gallons (A56438)
CASE 610 Sprayer...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56438)
2021 Unverferth...
