Hydraulic QA Coupler Sizing Questions
   / Hydraulic QA Coupler Sizing Questions #1
Porchfan
Oak Ridge, NC
2013 Kubota B2650 HSD, 2020 BX2380, JD LX-277 lawn tractor 2000
Hey Everyone.
I recently had a 3rd function remote added to my B2650. I want to replace the capped ends of the lines at the bracket the dealer put on with a couple QA couplers in place of the caps.
The dealer (or kit) put/had female to female nipple/adapter at the bracket on each line that is two different sizes. The end towards the valve is a bigger size then the capped end size. The valve side of the nipple is ~0.75. The implement end of the nipple is ~ 0.675.
QUESTIONS:
(1) What's the deal with that?
(2) What size QA coupler do I get on the implement end. I think I'll go with male QA ends.
Here are pics of both measurements
   / Hydraulic QA Coupler Sizing Questions #2
Thats just an adapter fitting.
Looks like a NPT to JIC bulkhead fitting. 3/8" NPT to 1/2 (-08) JIC fitting
Male Pipe (NPTF) x SAE 37° Flare (JIC) Bulkhead
You need fittings with 3/8 NPT to connect onto where the cap is.
And it appears they used teflon tape. Get rid of that and use a sealant or paste
   / Hydraulic QA Coupler Sizing Questions #3
Before you install MALE ends, do a little checking. I am no expert, but virtually all the remotes I have seen had female couplers. 3/8" hydraulic lines are likely the size of most implements you would use with that tractor.
   / Hydraulic QA Coupler Sizing Questions #5
Are you talking about using a coupler in place of a cap? Won't that leave the line open? Maybe I misunderstand you?
Jim
   / Hydraulic QA Coupler Sizing Questions #6
   / Hydraulic QA Coupler Sizing Questions #7
:thumbsup::thumbsup: (All 10 :)) Use one male & one female on the bracket, and one of each on the hoses, so they'll go together correctly every time you connect.
M and F Q-D couplers will seal when disconnected. (as best they can)
There seems to be 'micro-beads' in everything from toothpaste to laundry detergent these days. If there are any in your Teflon pipe dope they'll likely end up in your hydro filter. A worked-loose scrap of Teflon tape will as likely find a more troublesome place to go to.
   / Hydraulic QA Coupler Sizing Questions #8
I have, and often see, a pair of female couplers, so that no matter what you are hooking up, you can get the flow path you want. But in a perfect world, the male and female would also be fine. Leaking shouldn't be an issue.
   / Hydraulic QA Coupler Sizing Questions #9
Why would you need any sealant of any kind on a hydraulic fitting? Is that due to some flaw in the NPT threads? We use BSP,JIC,ORFS and Metric fitting and none of them require any extra sealing.
There seems to be 2 schools of thought on this; most Ag equipment have all 1/2" female couplings on the tractor and male on the implements. This is also how the factory rear remotes are delivered on (newer?) Kubotas. But a lot of CUTs have 3/8" couplings and most of those seem to use the one male/one female principle for each circuit. At least thats how all my Kubotas has been delivered, a 20-year model span.
I have decided to use the first method in the rear and the second for everything up front. That way I can borrow 3pt equipment from farmers around me, and still stay "CUT standard" for FEL and front mount equipment.
/Marcus
   / Hydraulic QA Coupler Sizing Questions #10
Npt requires sealant. Jic and o-ring fittings do not.
2020 Deere 50G (A53317)
2020 Deere 50G...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
