Hobart Handler 140 MIG Welder
   / Hobart Handler 140 MIG Welder #1
msb1766
Guilderland, New York
SC2450 Cub Cadet/Yanmar
I am thinking about getting a Hobart Handler 140 MIG welder, It is on sale at Tractor Supply for $469.99
Hobart Handler® 140 MIG Welder - Tractor Supply Co.
I looks like it comes with flux-core welding wire.
I want to use this welder with gas what mix of gas do you recommend? 75% Argon- 25% Carbon Dioxide?
What wire do I need to buy and what thickness?
   / Hobart Handler 140 MIG Welder #2
.030 wire will work great with the HH140. You can get the wire at TS, It should be Hobart wire. You will need a tank of gas 75/25 like you said. I am not sure of the welding supply comp. in your area.
   / Hobart Handler 140 MIG Welder #3
For a little hotter puddle, I'd go with 100% CO2. But you'll get a little more splatter then with 75% argon & 25% CO2.
   / Hobart Handler 140 MIG Welder #4
I have had one for a few months now, and it's been great. Got mine from Northern Tool for $449 with a coupon on top of their sale price. It makes real nice welds and is build real solidly. I have been using 0.030 flux core, mainly since I weld indoors/outdoors and it's always breezy here. I do plan to add a shielding gas setup when I have some time to experiment with it indoors.
   / Hobart Handler 140 MIG Welder #5
May need to change polarity inside the machine if you go to a gas shielded wire. If you use the 75/25, go with ER70S6 wire.
   / Hobart Handler 140 MIG Welder #6
Correct -- it ships wired for flux core (electrode negative). Would need to reverse the leads for gas.
   / Hobart Handler 140 MIG Welder #7
I bought one of those welders a year ago for about that price. Use 0.030 flux wire. It's a nice machine for the price. Haven't hooked up the gas supply yet for MIG.
Good luck.
I am glad to see positive reviews, I did not know about switching the polarity of the machine when using gas, Thanks.
The ER70S6 wire is that wire a common wire?
   / Hobart Handler 140 MIG Welder #9
I'm certain more than a couple small migs have been sold because the original owner wasn't aware of the polarity differences.
Terry
   / Hobart Handler 140 MIG Welder #10
The problem with getting the HH140 is that this will start............. and there are No pills for this... Ok view.JPG
2012 Chevrolet Silverado 3500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
1432 (A57192)
1432 (A57192)
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
