Hobart Handler 140 MIG Welder
   / Hobart Handler 140 MIG Welder #1
msb1766
Platinum Member
Guilderland, New York
SC2450 Cub Cadet/Yanmar
I am thinking about getting a Hobart Handler 140 MIG welder, It is on sale at Tractor Supply for $469.99
Hobart Handler® 140 MIG Welder - Tractor Supply Co.
I looks like it comes with flux-core welding wire.
I want to use this welder with gas what mix of gas do you recommend? 75% Argon- 25% Carbon Dioxide?
What wire do I need to buy and what thickness?
   / Hobart Handler 140 MIG Welder #2
.030 wire will work great with the HH140. You can get the wire at TS, It should be Hobart wire. You will need a tank of gas 75/25 like you said. I am not sure of the welding supply comp. in your area.
   / Hobart Handler 140 MIG Welder #3
For a little hotter puddle, I'd go with 100% CO2. But you'll get a little more splatter then with 75% argon & 25% CO2.
   / Hobart Handler 140 MIG Welder #4
I have had one for a few months now, and it's been great. Got mine from Northern Tool for $449 with a coupon on top of their sale price. It makes real nice welds and is build real solidly. I have been using 0.030 flux core, mainly since I weld indoors/outdoors and it's always breezy here. I do plan to add a shielding gas setup when I have some time to experiment with it indoors.
   / Hobart Handler 140 MIG Welder #5
May need to change polarity inside the machine if you go to a gas shielded wire. If you use the 75/25, go with ER70S6 wire.
   / Hobart Handler 140 MIG Welder #6
Correct -- it ships wired for flux core (electrode negative). Would need to reverse the leads for gas.
   / Hobart Handler 140 MIG Welder #7
I bought one of those welders a year ago for about that price. Use 0.030 flux wire. It's a nice machine for the price. Haven't hooked up the gas supply yet for MIG.
Good luck.
I am glad to see positive reviews, I did not know about switching the polarity of the machine when using gas, Thanks.
The ER70S6 wire is that wire a common wire?
   / Hobart Handler 140 MIG Welder #9
I'm certain more than a couple small migs have been sold because the original owner wasn't aware of the polarity differences.
Terry
   / Hobart Handler 140 MIG Welder #10
The problem with getting the HH140 is that this will start............. and there are No pills for this... Ok view.JPG
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2016 Ford F-150 Pickup Truck (A55852)
2016 Ford F-150...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A55853)
2009 Mariah SC23...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
UNUSED FUTURE FT-M48 48" HYD MIXING BUCKET (A57193)
UNUSED FUTURE...
2016 JLG 20MVL 19ft Aerial Platform Lift (A55851)
2016 JLG 20MVL...
