Shed Roof Pitch??
   / Shed Roof Pitch?? #1
dieselscout80
South Carolina
New Holland TC45DA
What is the least amount of pitch (inches of drop per foot) that is acceptable?
I live in South Carolina, so snow/ice loading is not much of an issue.
Is 1.5" per foot ok?
   / Shed Roof Pitch?? #2
I live in heavy snow country and recently built a 80 foot long drive shed with a classic shed roof. I don't really like this style, but I wanted a thirteen foot drive in height but without the overpowering look of a huge high roof on top of that just on account of the location. So the pitch is very modest, but with engineered trusses, I met code for the area and then spaced them even closer. I don't want to be told anything about unprecidented weather or snow amounts when the roof fails! Having said that, I am still a bit nervous! DSC03034.jpgDSC03313.jpg
   / Shed Roof Pitch?? #3
I would stay closer to 4 to 1. will handle heavy rain better with less blowing up under the shingles. Less ice damming backing up under the shingles.
1.5 to 1 is close to flat.
   / Shed Roof Pitch?? #4
I have a metal 8' x 12' storage building in which I keep the lawn and garden tools and it's 2" per foot. I don't think I'd want to go any less than that, but maybe 1.5" would do on an all metal building like mine, but I agree with Dave if it's going to be shingled roof.
   / Shed Roof Pitch?? #5
I live in heavy snow country and recently built a 80 foot long drive shed with a classic shed roof. I don't really like this style, but I wanted a thirteen foot drive in height but without the overpowering look of a huge high roof on top of that just on account of the location. So the pitch is very modest, but with engineered trusses, I met code for the area and then spaced them even closer. I don't want to be told anything about unprecidented weather or snow amounts when the roof fails! Having said that, I am still a bit nervous!View attachment 413807View attachment 413808
You will probably need a couple of friends to help you get the snow blower up on the roof to clear it.
   / Shed Roof Pitch?? #6
4/12 is standard for shed roofs means 4 in rise for every 12 in length
   / Shed Roof Pitch??
When we moved here in 2009 an existing out building had a shed roof with about 1.5" per foot with 2x6 trusses on 24" centers and it has been fine.
We are wanting to take the existing shed roof down and build a 19' addition. If 1.5" per foot will work that would be great, but want to ensure it lasts. I looked at metal roofing and some say not less than 3" per foot. on
   / Shed Roof Pitch?? #8
I wouldn't go less than 3/12 regardless of material. 4/12 is a good minimum pitch for most materials.
   / Shed Roof Pitch?? #9
1.5 " will work just fine in your area if shingled use low slope shingles if metal use ww2 ( double ribbed).
   / Shed Roof Pitch?? #10
The steeper the pitch the more room inside for storage and head room.
Less maintenance with a steep pitch, cheaper shingles.
Yes more lumber, more shingles but overall easier... iMHO !
AND... partly will depend if you want a certain look.
I am putting in a steel building in SoCal, I could get away with very little pitch but I chose an 8/12 to keep in line with the house and with a look similar to a New England Lobsta Shack.
EZ-GO Electric Golf Cart (A53314)
EZ-GO Electric...
2006 S/A Dry Van Trailer (A55788)
2006 S/A Dry Van...
PALLET OF SCAFFOLDING (APPROX. 18 PC) (A52706)
PALLET OF...
Hydraulic Hoses (A53316)
Hydraulic Hoses...
UNUSED Wheeled Dump Hopper (A47477)
UNUSED Wheeled...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
