Shed Roof Pitch??
   / Shed Roof Pitch?? #11
I am putting in a steel building in SoCal, I could get away with very little pitch but I chose an 8/12 to keep in line with the house and with a look similar to a New England Lobsta Shack.
Cool. Pictures?
   / Shed Roof Pitch?? #12
What is the least amount of pitch (inches of drop per foot) that is acceptable?
I live in South Carolina, so snow/ice loading is not much of an issue.
Is 1.5" per foot ok?
Match the roof pitch of the other buildings on the property so that all the buildings share a unified theme.
   / Shed Roof Pitch?? #14
This isn't the building but close.
One 10x10 door centered in the high peaked section and One 8x8 door in the lower roofed section but other wise the same thing... 32' wide x 36' deep.
Should be here in two to three weeks.
   / Shed Roof Pitch?? #16
When I had the porch built the inspector said 3/12 unless I went with a metal roof that seals on the connection between the pieces. Do you have an inspector to deal with, if you do you might as well make him happy because if he is not happy you won't be.
   / Shed Roof Pitch?? #17
That is guaranteed! Unhappy building inspectors make life hard and expen$ive!
   / Shed Roof Pitch?? #18
They can be a pain sometimes, but I have never run into one that wasn't trying to make something better or safer (even if others think it's overkill). Good ones are demanding but flexible and will give some slack based on trust.
   / Shed Roof Pitch?? #19
What are you using for the roof? If it's metal you can get away with 2:12 and sealant on the overlap. If you are going with shingles, 4:12 is the standard because water can get back up under the shingles. You can go with a flat roof with a membrane type roof. Basically you just put a solid piece of roof rated rubber over the whole roof and attach it to the sides. This is how RV's are done.
One of the biggest problems associated with flat roofs in my part of the country, East Texas, is the build up of leaves. Those leaves stay up there when it rains and once they get wet, they start to break down, turn into dirt, and then hold more water and eventually cause failure in the roof. You really have to keep the debris off of the roof with lower pitched roofs.
Eddie
   / Shed Roof Pitch?? #20
ww2 is just double ribbed metal roofing on low slope but gives less coverage than standard single rib. There may be single you can buy for low slope but I would certainly check the manufactures recommendations for min. slope. Using sealant Like Eddie said may be an option .
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
RHINO X1808 LOT NUMBER 43 (A53084)
RHINO X1808 LOT...
