3PH Pins
   / 3PH Pins
Sorry, Never mind...I just grew up on Ford tractors and plowed with Dearborn and Ford plows...the 101 was designed for tractors with 12.4 to 13.6 inch rear tires and the width from the center line of the tractor to the inside of the right rear tire is specific (such as a Ford 3000). Don't know how a 16.9" rear and the width of the centerline to the right rear of the the 6500 series might work or if significant adjustments would have to be made. Just saying.....BobG in VA
Bob,
I discussed this in the thread I started when I bought it.........here......... http://www.tractorbynet.com/forums/attachments/331834-ford-model-101-3-bottom.html
The measurements called for in the manual are just a couple of inches from the measurements I took off of the tractor. True.........that wide rear tire will not completely ride in the furrow. But I am having fun so far.
Guess I need a bigger plow for my fat rear tires!
Oh yeah...........I have a 20 series.
hugs, Brandi
   / 3PH Pins #12
Well I normally would never ever suggest any backwoods or hillbillish fix, but in this case I see no reason not to....
Use a ratchet strap from lift arm to lift arm, synch it up tight. Might add a strip of duct tape somewhere to complete the effect. This should work until a more "proper" fix could me made :)
   / 3PH Pins
Naw...........baling wire.
hugs, Brandi
   / 3PH Pins #15
hugs, Brandi
You dont need either one ... nor lynch pins. The telescopic stabilizers on the 20 series securely set the distance between balls. Just choose the appropriate holes on the vernier such that the balls are held firmly inward to the proper separation for the pins on the plow.
   / 3PH Pins
Technically, according to Farmwithjunk.............you don't need stabilizers if you have set up the plow correctly. According to you, I could just leave the lock pin out. But just think...................with enough slop...........and enough plow pressure just right........like hitting a root............your left lift arm comes detached from the plow..............your plowing and (at the time) looking forward.........then the tractor stalls.................you look back to see the rightplow pin is bent 90s in the lift arm's swivel.............now you have two messed up plow pins and you gotta do the walk of shame back to get chains to carry your broken plow home............................No Thankyou.
I'm a mechanic......I see operator error all the time.
hugs, Brandi
   / 3PH Pins
I picked up a longer Cat 1 hitch pin at TSC. It is the bolt on kind. I just might cut the threads off and the plow's pin off and have it welded on the plow. But first I am gonna skillfully radius the shoulder of the plow's pin and also put a concave radius on my Cat 2 swivel ball. It will be raining this weekend and this will be a fine out-of-the-weather job. Photos coming.
hugs, Brandi
   / 3PH Pins #18
hugs, Brandi
You dont leave any slop or you have to have the lynch pins. So dont leave slop unless tight together is a problem for plow operation.
   / 3PH Pins #19
hugs, Brandi
That should get you enuf room to use the lynch pin. From pic it doesnt lack much.
   / 3PH Pins
I took the end of the left lift arm off today and ground down the ball. I didn't grind off much material. I now have enough room for a 3/16th inch quick lock pin. I would prefer a 3/8th inch quick lock pin, but I can live with this. Mahindra Lift Arm On Ford 101 Plow.jpgMahindra Lift Arm Ball Getting Ground Down.jpg
hugs, Brandi
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
Year: 2016 Make: Tesla Model: Model S Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2016 Make...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2012 AMERITRAIL, INC. 30 T/A GOOSENECK TRAILER (A52472)
2012 AMERITRAIL...
