To Yield or Not
   / To Yield or Not #51
You yield. At that point you are no longer turning right, you are merging left into a traffic lane, which she is already in.
This is how our state looks at it. It seems about 25 years or so ago is when this kinda changed. As an example on the down ramp to enter an interstate yield signs went up many years ago for people merging right onto the ramp to yield to the left turners also wanting to go down the ramp. In the old days the guy turning right had the right of way as there was no sign and the left turner be darned. But this was changed, and it probably helps traffic flow that the person turning left has the right of way now as the right turner is merging now into their traffic flow as stated above.
So long story short, your photo all looks to be in order here.
   / To Yield or Not #52
Forget stop signs... how about traffic circles? Seen a few times people IN the circle stop to let others in. Combine that with a traffic light a block way which backs up into the circle... and you have a mess.
We have several of these "roundabouts" here in Branson now. it can get interesting at times.:laughing:
   / To Yield or Not
Look at this one. Assume North is up. Do you think that traffic that's coming southbound and turning right to go west on the other road, should yield to traffic that's turned left onto the same road from the northbound direction of the main road?
I believe that is exactly what everyone thinks my intersection is. It's clear the southbound would yield because he is nearly westbound when the other driver meets him at the merge point. Because this is light controlled there is also little risk of another southbound car proceeding straight through. You see where your distance between the turn and the merge is like five car lengths and the merger from the north is already nearing a parallel line with the westbound lane? In my case there is barely one car length of distance from intersection and merge. That doesn't leave enough reaction time and both vehicles are in full turn.
Further, once your south bound driver is in the curve he is committed to the merge, he can't get out of it. Therefore there is no risk to the one making a left turn that the southbound driver might change his mind and proceed straight.
There is one of your examples a few blocks from my intersection and it works fine because drivers expect it to work that way. Merge occurs when cars are nearly in same axis of travel. In my case our vehicles were not and at the least were 90° to each other. That's not a merge, at least not a natural one.
   / To Yield or Not #54
Have you looked at your photo from the first post, how is the yellow TRIANGLE in there and you get 90° You see the white line in front of the cars trying to turn, THAT's the start of her road. Sorry, that's how I see it.
414769d1425403847-yield-not-yield-not-jpg
   / To Yield or Not #55
Don't think the driver from the right turning right, has the right of way even without a yield sign, because of how the lane splits out before the intersection. they are entering into the road to the right. Would drivers leaving the shopping center turning right have the right of way over cars going straight from right to left? No they don't, with or without a yield sign.
with that said, If I'm the driver from the left turning left, and a car was turning right from the right, I would time my left turn to try to avoid a conflict, in case the driver turning right didn't yield.
   / To Yield or Not #56
Well, think about a standard intersection -- if drivers coming from the opposite direction are turning to the same side street, the one making the right turn has the right of way and the person making the left turn (across the other lane) is supposed to yield to the right turner. Nobody has signs in that case -- it's just common rules of the road that say the person turning right has the right of way over the person turning left. I think that aspect of it was was the OP found perplexing, and I agree to some extent.
Your example is correcst for a plain cross or T intersection, not where there is a 'merge ramp' as in his diagram.
Harry K
   / To Yield or Not #57
As is the case with the right turn into the mall that you posted the picture of. The writing on the road says right turn only and you cannot (legally) leave that lane once you get past the start of the yellow lines.
As for yielding, IF there wasn't the yellow triangle at the right turn lane (ie: if it ended like the left turn lane does) cars turning left would have to yield to cars turning right, but being as there is the yellow triangle there, you must yield to those making left turns.
Here is an example of an intersection without the yellow triangle painted on the road, a driver in lane B who is making a left turn into lane C must yield to a driver in lane A UNLESS the driver in lane B has a green arrow:
Here is another version of your intersection, because of the yellow triangle (I think its called the gore), the driver in lane A who is making a right turn into lane C must yield to any traffic coming from lane B:
The reason is that due to the triangle the intersection is seen (by law) as being the same as the one posted by Country Geek in that, the driver in lane A who is making a right turn into lane C must yield to any traffic coming from lane B:
Aaron Z
   / To Yield or Not #58
Nice try but even in your intersection the left turning driver _is_ already parallel with the lane by the time he gets to the merge point, you aren't.
Harry K
Harry K
   / To Yield or Not #59
Well, I agreed with the lady when jlgurr had a yield sign. Then I agreed with jlgurr when it turned out he didn't.
Now I agree with the lady again since the paint has been pointed out that makes it a merge into her existing lane.
Sorry jl! :)
   / To Yield or Not
UNCLE. :D All y'all can't be wrong. I humbly cede my stance. Thank you everyone for your responses and constructive criticism. :thumbsup:
Sent from my iPhone using TractorByNet
City of Lakeland (A51691)
City of Lakeland...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55301)
UNVERFERTH 330 -...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
