Water For Fuel??????????
   / Water For Fuel?????????? #41
definatally not 100%
The suns energy is something like 1000w per sq meter.
A tree or trees large Enough wood to make 1 cord of firewood is gonna have alot of square meters exposed to the sun for alot of years. So I dont think it is even close
   / Water For Fuel?????????? #42
Please, Mr Redneck in training.
Put down the physics book and walk away slowly.
   / Water For Fuel?????????? #43
If you really want to release some energy. Get some 3H hydrogen together and give it a good squeeze . Ka BOOOOOOOOOM.
   / Water For Fuel?????????? #44
It is bad you don't have a picture. My guess would be it had wood pyrolysis generator on the truck bed.
Why would a wood smoke generator have mason jars filled with spooled wire connected in parallel and liquid and tubing going to each jar? It wouldn't. Someone running current through water to generate hydrogen would be applying that current with those wires probably to metal plates submerged in those jars, and using the tubes to collect the hydrogen.
   / Water For Fuel?????????? #45
Actually no. Deuterium has properties helpful in reactors, but is not radioactive nor used in bombs
   / Water For Fuel?????????? #46
Not a 100%, probably on the order of 5%.
I am not saying how much energy you will be able to use. I am saying what amount of energy will be released when the process is reversed in example by burning. If you think that it is 5% then where the remaining 95% goes.
   / Water For Fuel?????????? #47
The pyrolysis gas is dirty and "wet". The jars capture condensate that can be vaporized and burned in the engine. Google "Wood pyrolysis generator" or "wood gasification".
https://www.google.com/search?q=woo...c%2FBoyt%2Fpyrolysis%2Fpyrolysis.html;600;400
   / Water For Fuel?????????? #48
2012 KOMATSU GD655-5 (A52472)
2012 KOMATSU...
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2004 Ford Taurus Passenger Car (A51694)
2004 Ford Taurus...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
