Rear Hydraulics on a 2816 Mahindra
   / Rear Hydraulics on a 2816 Mahindra #21
In the right picture, there is a port on the end plate that is plugged, but can not tell if it is PB.
A PB port will either have a small threaded hole for a hex screw or have an open for a PB adapter that will separate the galleries so the PB can exit the valve for downstream operations.
Are there any markings on that port?
   / Rear Hydraulics on a 2816 Mahindra #22
Here is a Land Pride BH.
Look at page 11 and you will see that some BH have PB on the end of the valve.
http://www.landpride.com/ari/attach/lp/public/manuals/340-131m.pdf
J.J.
The valve has a port on that end that has a hex plug in it. If that (which it appears to be the PB port) are parts available to make it a PB port?
Is the PB sleeve the same for this valve as others?
Randy
   / Rear Hydraulics on a 2816 Mahindra #24
You have to know the manufacturers name and model number.
PB adapters are different and made for specific valves.
Is the letters PB stamped on the valve or BYD.
Hydraulics 2.pngAm i thinking correctly??
Hydraulics.png option 2?
   / Rear Hydraulics on a 2816 Mahindra #26
Both diagrams look correct.
Thanks J.J.
I will review that BH valve closer when i get a chance. I hope i can find the PB parts for it.
   / Rear Hydraulics on a 2816 Mahindra #28
It is really only a problem if the BH is a 3pt operated, but even that can be solved with the valve I posted.
People with 3pt log splitters can use my idea also. Position the log splitter using 3pt, then switch over to flow to log splitter.
le
J.J.
Yes i understand that now. I would rather have all the hydraulics working if i can make it happen. I think the valve could be a Dinoil DN35
https://sklep.dzwigi.net.pl/upload/pdf/Katalog Dinoil.pdf
If iam looking at this correctly the BH has the return in T1 which is PB i think. It has some sort of adapter in T1 with the hose. Is it possible that the H is setup for PB and missing the tank return hose at T?
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
2018 JOHN DEERE 333G SKID STEER (A51242)
2018 JOHN DEERE...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
