Small dump trailer, bad descion or good?
   / Small dump trailer, bad descion or good? #1
kevinwak
Northern Alberta
John Deere 2520
I am planning on doing a bunch of landscaping in my back yard this summer. I was thinking of renting a dump trailer to haul the soil across the yard. When calling the local trailer shop to inquire about rentals I also asked about purchase prices.
To me the 14-16' 14,000 pound dump trailers seem over kill for around the yard needs. Would I regret buying a small 10' 7,000 pound dump? To me it seems the perfect size, I can pull it with the half ton. It can go anywhere in the yard without causing huge damage. I am just wondering if I. The king run I will regret not getting a heavier duty and larger capacity unit. My next truck will be a one ton, so even though I can't load to capacity now on a big one, I would be able to in years to come. I think one of the main hindrances in my brain is that I won't be able to fit my tractor in a 10' dump, if I am going somewhere I will have to haul the tractor separate.
Buy a small trailer? Bug a big trailer? Or just rent?
   / Small dump trailer, bad descion or good? #2
I would step upto a 10,000 gross trailer, it won't cost much more. Be careful, there are several grades of dump trailers. Some are pretty light duty.
   / Small dump trailer, bad descion or good? #3
Being around dump trailers I wouldn't own anything less than a 14' 14,000# unit.
My uncle has had one since about 2007 and hauled it with a Expedition then a F150. He only loads it to 6000# since the trailer itself weighs 4200#. This works fine behind his half tons.
I load it to the max behind my F350.
I have used 7K and 10K units. 2.5 and 3 tons payload respectively is nothing. They are just way to easy to overload.
Chris
   / Small dump trailer, bad descion or good? #4
I have been considering a dump as well. It sounds like we have the same dilemma- my current truck can tow a 7000 lb trailer, but I am due for a new truck in a year or two, and I know I will buy one that can tow at least 10,000lbs.
If I really need one before I buy a new truck, I'll go with a single axle 5200lb model- you gain very little payload with a 7000lb trailer. Much of the increase is in the weight of the trailer when compared to the single axle model. I have considered getting a 10k trailer now, but I would only be able to haul about 3500 lbs of material behind my current truck- about the same as the single axle. That's why I probably will wait until I get a new truck.
Will
   / Small dump trailer, bad descion or good? #5
My friends just bought one new for ranch use... it has two 3500 axles and so far they are pleased with it and love the stake pockets and load tarp.
Problem his is a 10k trailer reuires a commercial license so to go legal it has to be under that for most of us and covered loads are the law for bulk...
Going heavier also increases trailer weight a lot... their tow vehicles are rated between 7 and 8k...
This is light duty in that it would be easy to overload with rock... company told them 1.5 yards of rock no problem...
They use it for hay, cleanup, seasoned firewood and once already to move the L3800...
I think it was $4200
   / Small dump trailer, bad descion or good? #6
I have a small 6x10 tandem axle PJ dump that I love. Very light and pulls like a dream. You can back it in just about anywhere. It was custom ordered with 7k axles so you can hardly over load it without side boards. I could've de-rated the 14k gvw at the dealer but to save on plates but I haul heavy so I left it alone
   / Small dump trailer, bad descion or good? #7
It is easy to over load anything with gravel. The loader at the local gravel yard loads 8 ton a scoop. My little 1 ton truck easily holds 5 ton.
   / Small dump trailer, bad descion or good? #8
Sounds like many don't have the 10,000 commercial license problem?
My 12k PJ tractor transport is de-rated to 9,999 lbs...
A small dump with 14k axles would cover just about anything I can think of.
   / Small dump trailer, bad descion or good? #10
Here's my $5K 16ft dump trailer I just got :)
2018 Honda Rubicon TRX500FA5 4X4 ATV (A59231)
2018 Honda Rubicon...
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
iDrive TDS-2010H...
