Kubota BX2360 Transmission Fan
   / Kubota BX2360 Transmission Fan #1
Lilypup
Parkersburg, WV
Kubota BX 2360
Just noticed that 3 of the 10 blades on my transmission fan have broken off. How serious an issue is this? I know this repair will be expensive. Everything seems to running fine.
   / Kubota BX2360 Transmission Fan #2
Hi. Welcome.
The fan is very important to keeping your trans cool. Three blades is not that critical. The replacement is not that difficult. I replace the fan on my BX in about 30 minutes. I think the fan blade cost $26.
Might want to install a shield to protect the fan. On my BX it is a simple sheet metal bolted to the frame to deflect brush from getting to the fan.
I saw a file on how to replace the fan that seemed to indicate that one would need to disassemble just about everything.
   / Kubota BX2360 Transmission Fan #4
Hi. Welcome.
Wow, 30 mins! :shocked:
That is fast considering what I've seen others have to do.
Not sure if your BX2200 is the same setup as this procedure but I doubt I could do this in less than an hr.
  • Kubota BX HST FAN replacement procedure.pdf
   / Kubota BX2360 Transmission Fan #5
Certainly did not need to remove the fenders. Just the floorboard and seat. The fan is flexible so slipped in without a problem. Looking at it now I think it could be replaced from the bottom as well just easier with the floorboard out of the way.
   / Kubota BX2360 Transmission Fan #6
   / Kubota BX2360 Transmission Fan #7
The BX2200 is pretty much a totally different machine than the BX2360. Different engine, trans, frame, body, front axle, brakes, 3 point hitch, hydraulics, loader,.... The fan is about the only part that will interchange.
Replacing the fan is a completely different job.
2016 FORD F-450 9FT SINGLE AXLE DUMP BODY (A52141)
2016 FORD F-450...
2002 Pierce Tilt Cab Hale Pumper Fire Truck (A50323)
2002 Pierce Tilt...
2005 Ford F-550 XL (A50120)
2005 Ford F-550 XL...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
Cat TH407C Telehandler (A52748)
Cat TH407C...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52748)
Toyota 6FGU25...
