How do you get curl cylinders back in time?
   / How do you get curl cylinders back in time? #1
williaty
Licking County, OH
JD 1023e
While re-attaching the H120 loader to my 1023e, I've been thinking it's a little harder to connect the loader to the tractor and a lot harder to disconnect/connect the bucket to the loader. Today, I looked at it from the right angle and finally saw the problem. The curl cylinders are out of time. One is about 1.5" farther extended than the other, which obviously throws the bucket QA out of whack and also affects the loader QA since you push the loader off the floor via the bucket.
How the heck do I get the curl cylinders back in time? I'm fairly sure this is going to involve manually moving just one cylinder until it's at the same extension as the other cylinder, but I have no idea how to do this.
Help!
   / How do you get curl cylinders back in time? #2
I'd try repeatedly running to max extension then max contraction, max extension, max contraction....while checking & maintaining fluid level.
   / How do you get curl cylinders back in time? #3
Look for a missing/broken pin(parts key 5) on cylinder timing rod.
OK, a bunch of data, not sure what to make out of all of it.
1) Mid-range between max curl and max uncurl, the difference in cylinder extension is about 1.5". The difference in paddle position is about 4", which makes it difficult or impossible to pick up the bucket and also makes one corner of the bucket, when mounted, hit the ground first which means I can't dig a flat-bottomed hole. I assume this means it'd also be impossible to carry something on a set of forks because they'd constantly be drooping to one side.
2) The timing bar is not broken and both pins are solid and properly in place.
3) At full curl if you hold it there for a moment the paddles line up and cylinder extension is equal. At full curl, the pins in the timing bar are loose and you can rattle them back and forth with your fingers.
4) At full uncurl if you hold it there for a moment the paddles line up and the cylinder extension is equal. At full uncurl, the pins in the timing bar are loose and you can rattle them back and forth with your fingers.
5) Anywhere in the working range between full curl and full uncurl, the cylinder extension is unequal and the paddles do not line up. At this point, the timing bar is tight on the pins and you can't force them to move or twist even with a pair of pliers. The right paddle will always move farther/faster than the left paddle
6) The positioning difference grows as you move the system away from either end of the range. So you hit one end of travel, the paddles line up, then you start moving the other direction and they get worse and worse out of alignment the farther you go.
So, it looks like every piece of the system is in place, they just get too far away from each other during normal operation. It's like the timing bar's holes are either wallowed out so that the pins are loose (so there's too much slop in the system to actually keep them in time).
So what do you guys think now?
   / How do you get curl cylinders back in time? #5
Sounds like it's possibly a fluid delivery problem. Is there a place to check / compare pressure after the quick disconnects individually on each cylinder during operation? If not a physical check or replacement of the quick disconnects on the slow side might cure it.
   / How do you get curl cylinders back in time? #6
Off hand I'd venture a guess you have something bent out of shape but you'll have to do a few checks to track the cause down. If you swap cylinders from side to side and the same condition continues to exist you'll have proved the cause isn't cylinder related. Another test involves swapping the hoses between the splitter junction blocks and the cylinders doing one set at a time; by this I mean swap the ones that see pressure in the uncurl mode from one side to the other and then do the hoses that see pressure in the curl mode. This will test if the internal liner on one hose is acting as a flow restriction...they have been known to peel lose and fold over under flow and act as a plug in the line. To check if your loader is bent, park the tractor on level concrete and then make sure the tractor is level from side to side at the back by measuring down from a fixed point on each side of the tractor at the rear to the concrete and adjusting as needed. Once the tractor is square with the concrete you can start to measure points on the loader arms down to the concrete and noting if there are any differences from side to side.
   / How do you get curl cylinders back in time? #7
Mace has possibly a good remedy here. Try to very slowly curl and uncurl with the loader off. See if any excessive binding/twisting happens at your timing bar. If it goes smooth, I would check for loose quick attach loader pins, curl cylinder pins, and excessive play at your timing bar connections. If your loader has been home made, repaired, or fabricated, then It could be a bad positioning of your cylinder mounts on the loader arms. But per your symptoms, I would dought about this possibility.
   / How do you get curl cylinders back in time? #8
Your timing rod is twisted.
,,, Put the most extended QA carrier against something solid and push [uncurl] slowly until the retracted one is out about an inch more than the one restrained. ... Check and repeat, adjusting amt of uncurl used.
larry
   / How do you get curl cylinders back in time? #9
It would seem that if a twisted timing bar (or something else being bent) the side that leads to uncurl would trail while curling, no?
   / How do you get curl cylinders back in time? #10
larry
Yeah, on closer read its clear your timing rod is NOT twisted. It appears that your left cyl has a LOT of drag. ... Probably a bent rod.
larry
   / How do you get curl cylinders back in time? #11
Check for one bad cyl, maybe bent or piston came loose.
   / How do you get curl cylinders back in time? #12
When the QA is unhooked from the bucket it sounds like the timing bar is simply bent or broken pin.
But here you are saying they are out of time even when hooked to the bucket and the bucket digs uneven ?? I don't get how it can do that, the out of time tilt cylinders would have to twist the entire bucket or fork frames to do that.
How is that possible ??
Sounds like 2 separate issues to me.
The QA is out of time when unhooked ( bent timing bar) and the loader frame is uneven for some reason. ( low tire, bent/loose loader frame, Etc.) causing it to dig uneven when the bucket is on.
   / How do you get curl cylinders back in time? #13
Are you getting both of the QA pins to engage correctly?
Yes, the bucket is getting picked up properly.
So I played with it a little more today. What happens is that, coming from the limit of travel, the right cylinder shoots out (or retracts) an inch or so before the left cylinder starts moving. This appears to be when the timing rod comes into play and forces the cylinders to stay somewhat together. From that point on, the cylinders move more slowly than the right one initially did but they move out together (though with the initial offset preserved). When they get to the other limit of travel, the right one stops moving and the left one keeps going for a moment until it catches up.
When I re-attched the bucket today, I uncurled about half way to make the bucket easy to hook, then got off the tractor and manually lined up the shoes so they were in the same plane (So, dieselshadow, that's a yes to your question about whether I could manually move the shoes into alignment mid-range). Then I got back on the tractor and picked up the bucket using only the main boom lift until I had both sides of the bucket securely hooked before curling back so I could get the retaining pins in. This made it MUCH easier to pick up the bucket!
Still doesn't solve the fundamental problem though, just works around it. It's like the timing bar/pins/mount has so much play in it that it allows about 4" of misalignment at the top of the shoes which causes the other problems.
   / How do you get curl cylinders back in time? #15
Why JD puts a QA torque tube on some of their models the size and strength of a number 2 pencil is beyond me.
Surprised they ever work at all.
You are having problems hooking up the bucket because of the torque (timing) tube.
But that will not cause your bucket to dig un level.
If your bucket is not digging level after being hooked up and latched you have a separate issue.
Fix the timing bar, then check your tire pressures is the first thing I would do.
   / How do you get curl cylinders back in time? #16
Unhook the cyls. from the QC hookup and run the cyls in and out and see what going on. Now one well move before the other, but should be able to hold it by hand and then the other one should start to move. If you can't hold the one moving by hand then the other one is binding up. That might be why the timing bar is longgated and twisted. Two things well make that happen bent rod or piston is loose.
   / How do you get curl cylinders back in time? #17
With the forces involved, you would shear off a hardened 1/4 index pin with no problem. I started out replacing sheared pins when I got my tractor 10 years ago but gave up after a few years. when the bucket, forks, snow plow or whatever is clipped on it should have more than enough strength to keep the paddles indexed. Its only when hooking up that you will notice the paddles out of sync, and even then its just a case of putting one blade in place and then rotating the other with the joystick. When they line up, lift the loader so the pins pop in...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
2018 John Deere Z997R (A53317)
2018 John Deere...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
2021 Deere 331G (A53317)
2021 Deere 331G...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
