2015 Hay Season
   / 2015 Hay Season #111
Nice! I didn't realize that either of those tractors would reach that high.
Well you just about have to leave the two lower little spikes in and spear them a little below center to get them up that high and they need to be very dense bales, soft cores would just go everywhere.
   / 2015 Hay Season #112
Here's something that pulls a little harder on a disc mower and tractor, Oats. These Oats made about 3 1/2 tons of hay per acre. He cut it off about 3-4" high using High Stubble shoes on the DiscBine. The 5065M had trouble pulling the older mower they had a Kuhn FC243RTG in Oats this thick, it was a 7'10" cut.
https://www.youtube.com/watch?v=nbE5xjvFRTY
   / 2015 Hay Season #113
It seems most of you have been getting the water you need. (in some cases more than you need) here in Utah it has also been very wet. This is not the norm for this area. My own field is looking better than it ever has. I now have all the equipment I need to take care of my own place so I'm really looking forward to cutting and bailing within a week or two. The weather will decide when I cut. The bailer and swather are old but I have gone through them, replaced everything that even looked worn, adjusted belts and chains, greased and lubed everything that moves. I did not repaint them.:) So hopefully it all works like it should. Best of luck to all of you. DSCN1964.JPG
   / 2015 Hay Season #114
It's been so dry here in our part of Southwest Virginia. The kicker is that there has been 30% - 80% chance of rain about every day for the past two week and the next 10 days don't look any different, still no rain.
Being tired of waiting for a good forecast I decided to heck with it and mowed some tonight. I must say this is the first time I hope it does get rained on. We need it bad.
   / 2015 Hay Season
Hope things work out DT.
I was going to start getting equipment out today but wife had other plans for me so tomorrow going to get everything out,service it and see what need pickup to be ready before I go back to work. Pastures going to need a week at least before try it,good weather in the forecast.
   / 2015 Hay Season #116
Same here DT86. We were getting good rains up until the middle of April and since then we've had 0.25" total. It's terrible, pastures are burned up and eaten down. If the corn doesn't get rain within a week it's going to be lost at 12" high. They are already feeding the herd here 2 round bales a day and that's what they normally get in the dead of winter.
   / 2015 Hay Season #117
seems like it rains every other day here, very humid as well....and temps at night dropping to the lower 50's -- all a mixture for NO hay cutting.
Grass fields are 4 or 5 feet tall....can't believe it. Just had another neighbor stop by yesterday asking if I'd 'take care' of his 15 acres. Fertilize and keep the weeds down and I can have the hay for no cost. That puts me up to around 70 acres I'll do this year.
   / 2015 Hay Season #118
It seems most of you have been getting the water you need. (in some cases more than you need) here in Utah it has also been very wet. This is not the norm for this area. My own field is looking better than it ever has. I now have all the equipment I need to take care of my own place so I'm really looking forward to cutting and bailing within a week or two. The weather will decide when I cut. The bailer and swather are old but I have gone through them, replaced everything that even looked worn, adjusted belts and chains, greased and lubed everything that moves. I did not repaint them.:) So hopefully it all works like it should. Best of luck to all of you.View attachment 427368
that is some pretty country! Nice pic but you realize that orange doesn't go very well with red - right?
   / 2015 Hay Season #119
Rained hard here over the weekend but now the forecast is for a dry week so my hay will be going down later today. I hope the forecast is correct!
   / 2015 Hay Season #120
Finally looks like I'll be able to get into the fields in a day or two. Going to try and get the mower hooked up tonight.
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
