Ford 917A Flail bearing housings
   / Ford 917A Flail bearing housings #1
jedolson
Scholls, Oregon
Ford 8N, 9N, 4000, JD 790
One of the bearing housings that hold the roller busted out. Got new ones and bearings and snap rings. This looks like a pretty straight forward replacement (as long as I can get it lifted and positioned right). Have not done this before so any advice is most appreciated. Don't have a tool to handle that type of snap ring...hows that work...get one end started, use pliers and then knock em in?
   / Ford 917A Flail bearing housings #2
Pictures?
   / Ford 917A Flail bearing housings #3
GOD NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The NAPA snap ring tool set has an inner and outer snap ring pins
and is not very expensive so there is no need to plier handle a good
snap ring as the ring will be damaged if you try to use a set of pliers..
   / Ford 917A Flail bearing housings #4
I've installed and removed a LOT of snap rings with pliers/screwdriver. Just don't force it to the point of bending the snap ring. After you remove it, lay it on a smooth surface. If it lays flat, it's fine.
If you ruin it I think it would be easy to replace at any AG equipment dealership.
In the case of these particular snap rings, I don't quite see the purpose?? The roller is captured by the bearing housings and can't move laterally. The bearing housings can't move outward because of the casting in the bearing housings.
But if you got 'em, use 'em. :)
2008 JCB 190 ROBOT SKID STEER (A60429)
2008 JCB 190 ROBOT...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
