1952 Ford 8N 302 v8 conversion
   / 1952 Ford 8N 302 v8 conversion #181
It looks like you have the rears over inflated, and the fronts under inflated. That increases the rake by at least a few inches I'd bet. Maybe that's on purpose, but I'm mentioning it in case it would help with your oil.
Definitely a tough drag looking/sounding tractor.
   / 1952 Ford 8N 302 v8 conversion #182
Could also just put bigger tires on the front. I've seen that done on cultivator tractors where the rears were changed to really tall tires.
   / 1952 Ford 8N 302 v8 conversion #183
without power steering, larger fronts will steer harder. if it has PS.. then yep.. a possible fix.
   / 1952 Ford 8N 302 v8 conversion #184
Would have looked good with some 16.9X24's on it (those 28's look way too tall for the size of the tractor, just my opinion). Since you have a rear sump oil pan, and probably a stock volume oil pump you shouldn't have a problem with engine oil. The rear end oil with those tall tires that would have to be a look, and see how much oil is back there. Do you plan on using the 3 point, or pto?
   / 1952 Ford 8N 302 v8 conversion #185
Anybody go up or down hills in their car or truck? I bet the oil still flows.
Thanks everyone for your thoughts. I didn't realize that wider tires would also be taller.
I do have to inflate the fronts fully as they have lost a bit of air since last summer.
Also, when I have the beet juice added to the rear wheels, I will have the rears deflated to get a better squat and grip. That should level it out some. If that doesn't work, I could go to 19" wheels in the front. Time will tell.
I have to lower my wheelie plates too cause as they are, they are too high to be of much use.
Anyhow, watch for my next thread. I am making a Mini-Me 8N for my wife. I am starting with someone's Power Pup DIY from Science and Mechanics August 1961 plan then will add the Awesome Henry Garden Tractor 8N kit and a Honda 23HP horizontal shaft engine.
   / 1952 Ford 8N 302 v8 conversion #187
That sounds like an excellent project. Maybe you could post the link on here so we don't miss it.
Off to the show and pull this weekend, Aug 14-16, 2015. Got everything working the way I want. See if I can hook up those bigger tires.
   / 1952 Ford 8N 302 v8 conversion #190
hey good luck and remember pictures :thumbsup:
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
Universal Mount Equipment Seat W/ Headrest & Arm Rests, and Seat Belt (New/Unused) (A59225)
Universal Mount...
2009 MACK PINNACLE(INOPERABLE) (A58214)
2009 MACK...
2022 Belgrade Steel 350 Barrel 65 Ton T/A Towable Cement Silo (A56857)
2022 Belgrade...
2019 Komatsu WA470-8 Articulating Wheel Loader w/Quick Coupler, PIN# KMTWA129JJNA49506, Turbo Die... (A59076)
2019 Komatsu...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
