1952 Ford 8N 302 v8 conversion
   / 1952 Ford 8N 302 v8 conversion #181
It looks like you have the rears over inflated, and the fronts under inflated. That increases the rake by at least a few inches I'd bet. Maybe that's on purpose, but I'm mentioning it in case it would help with your oil.
Definitely a tough drag looking/sounding tractor.
   / 1952 Ford 8N 302 v8 conversion #182
Could also just put bigger tires on the front. I've seen that done on cultivator tractors where the rears were changed to really tall tires.
   / 1952 Ford 8N 302 v8 conversion #183
without power steering, larger fronts will steer harder. if it has PS.. then yep.. a possible fix.
   / 1952 Ford 8N 302 v8 conversion #184
Would have looked good with some 16.9X24's on it (those 28's look way too tall for the size of the tractor, just my opinion). Since you have a rear sump oil pan, and probably a stock volume oil pump you shouldn't have a problem with engine oil. The rear end oil with those tall tires that would have to be a look, and see how much oil is back there. Do you plan on using the 3 point, or pto?
   / 1952 Ford 8N 302 v8 conversion #185
Anybody go up or down hills in their car or truck? I bet the oil still flows.
Thanks everyone for your thoughts. I didn't realize that wider tires would also be taller.
I do have to inflate the fronts fully as they have lost a bit of air since last summer.
Also, when I have the beet juice added to the rear wheels, I will have the rears deflated to get a better squat and grip. That should level it out some. If that doesn't work, I could go to 19" wheels in the front. Time will tell.
I have to lower my wheelie plates too cause as they are, they are too high to be of much use.
Anyhow, watch for my next thread. I am making a Mini-Me 8N for my wife. I am starting with someone's Power Pup DIY from Science and Mechanics August 1961 plan then will add the Awesome Henry Garden Tractor 8N kit and a Honda 23HP horizontal shaft engine.
   / 1952 Ford 8N 302 v8 conversion #187
That sounds like an excellent project. Maybe you could post the link on here so we don't miss it.
Off to the show and pull this weekend, Aug 14-16, 2015. Got everything working the way I want. See if I can hook up those bigger tires.
   / 1952 Ford 8N 302 v8 conversion #190
hey good luck and remember pictures :thumbsup:
IVEY'S 7' AERATOR/PLUGGER (A58375)
IVEY'S 7'...
Enmark Z Spray (A53316)
Enmark Z Spray...
White 6138 Planter (A59814)
White 6138 Planter...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2025 Swict 66in Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
