1952 Ford 8N 302 v8 conversion
   / 1952 Ford 8N 302 v8 conversion #181
It looks like you have the rears over inflated, and the fronts under inflated. That increases the rake by at least a few inches I'd bet. Maybe that's on purpose, but I'm mentioning it in case it would help with your oil.
Definitely a tough drag looking/sounding tractor.
   / 1952 Ford 8N 302 v8 conversion #182
Could also just put bigger tires on the front. I've seen that done on cultivator tractors where the rears were changed to really tall tires.
   / 1952 Ford 8N 302 v8 conversion #183
without power steering, larger fronts will steer harder. if it has PS.. then yep.. a possible fix.
   / 1952 Ford 8N 302 v8 conversion #184
Would have looked good with some 16.9X24's on it (those 28's look way too tall for the size of the tractor, just my opinion). Since you have a rear sump oil pan, and probably a stock volume oil pump you shouldn't have a problem with engine oil. The rear end oil with those tall tires that would have to be a look, and see how much oil is back there. Do you plan on using the 3 point, or pto?
   / 1952 Ford 8N 302 v8 conversion #185
Anybody go up or down hills in their car or truck? I bet the oil still flows.
Thanks everyone for your thoughts. I didn't realize that wider tires would also be taller.
I do have to inflate the fronts fully as they have lost a bit of air since last summer.
Also, when I have the beet juice added to the rear wheels, I will have the rears deflated to get a better squat and grip. That should level it out some. If that doesn't work, I could go to 19" wheels in the front. Time will tell.
I have to lower my wheelie plates too cause as they are, they are too high to be of much use.
Anyhow, watch for my next thread. I am making a Mini-Me 8N for my wife. I am starting with someone's Power Pup DIY from Science and Mechanics August 1961 plan then will add the Awesome Henry Garden Tractor 8N kit and a Honda 23HP horizontal shaft engine.
   / 1952 Ford 8N 302 v8 conversion #187
That sounds like an excellent project. Maybe you could post the link on here so we don't miss it.
Off to the show and pull this weekend, Aug 14-16, 2015. Got everything working the way I want. See if I can hook up those bigger tires.
   / 1952 Ford 8N 302 v8 conversion #190
hey good luck and remember pictures :thumbsup:
1969 Lincoln Continental Mark III Sedan (A56859)
1969 Lincoln...
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
IRanch Mini 38" Grapple (A57149)
IRanch Mini 38"...
SKID STEER ATTACHMENT RAKE (A58216)
SKID STEER...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
