Any dual Cat1/Cat2 quick attach hitches?
   / Any dual Cat1/Cat2 quick attach hitches? #31
Maybe it's not the tractor that needs the cat1-2. Maybe it's the implement. Impl Mnt Pin Cat 1&2 Lght.1-13/1
Just a thought. If your implements are wide enough for a 2 then swap pins. And but a 2. If not get the 1.
   / Any dual Cat1/Cat2 quick attach hitches? #32
Good points. But I've never saw a CAT I implement that was CAT II width, or visa versa.
   / Any dual Cat1/Cat2 quick attach hitches? #33
Should have added....
My Ford can be converted to either. It is categorized as a CAT I/CAT II tractor. When hitching to a CAT I implement the 3pt arms are together as far as the telescoping swaybars will allow. I think that's why you rarely see a tractor built today that will claim that ability.
   / Any dual Cat1/Cat2 quick attach hitches? #34
I am considering building one at this point, but not liking the task of cutting out the hooks as they'll need to be quite thick.
This is my plan. I'd started a thread this spring in the build-it-yourself section that hasn't gotten very far with too many other projects on my plate. It's my plan to have a local shop cut the hooks with a lazer or waterjet.
   / Any dual Cat1/Cat2 quick attach hitches? #35
Richard, my Caroni flail has Cat1 spacing between lower pins but Cat 2 HEIGHT on the upper pin.
Had to make a couple "drop links" from 1/2" FB so I could use it on the Cat 1 QH. Weird... Steve
   / Any dual Cat1/Cat2 quick attach hitches? #36
No issues from me guys. :drink:
I went to buy the Speeco Cat1 yesterday and didn't. Not impressed with the quality at all. I am considering building one at this point, but not liking the task of cutting out the hooks as they'll need to be quite thick.
Why not get a harbor freight one? With the 20% off it's hard to beat. The materials alone would close to the price unless you already have the metal or a good surplus place with drops? I've used the HF one and it seems plenty strong
Brett
   / Any dual Cat1/Cat2 quick attach hitches? #37
Cat 1 and Cat 2 top pin height should be the same, if built to quick hitch specs.
Implement specs:
Hitch specs:
Bruce
   / Any dual Cat1/Cat2 quick attach hitches? #38
Bruce, almost all the info I have on 3PH agrees - not sure where I found this one though, but apparently Caroni agrees with it... Steve
  • 3-pointHitchSpecs.pdf
   / Any dual Cat1/Cat2 quick attach hitches? #39
BukitCase, your chart shows standard implement 3 point hitch dimensions (not quick hitch compatible.)
Bruce
   / Any dual Cat1/Cat2 quick attach hitches? #40
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A51572)
2021 Big Tex...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
1972 Volkswagon Beetle (A51572)
1972 Volkswagon...
2016 CATERPILLAR 306E EXCAVATOR (A51246)
2016 CATERPILLAR...
