Ford 6.4 diesel reviews
   / Ford 6.4 diesel reviews #11
I had a co worker whose husband bought one used. Something like 70,000 miles on it. They bought the high dollar extended warranty, lucky for them. It had the cab off something like 4 times, maybe more. New short block, turbos, injectors, etc. They got rid of it finally when it was running good but it was going through a regen every 75 miles. DP is correct, at least with a 6.0 you know what you need to do to fix it.
Are the later model 6.0 better then the earlier models??
   / Ford 6.4 diesel reviews #14
Are you sure they are cheap to fix??? I've owned but not bullet proofed it and put almost as much as paid for it into it
You had a bad mechanic that threw parts. $6500 will get you one heck of a stout 6.0 around here with head studs, gaskets, egr delete, coolant filter, turbo overhaul, injectors, exhaust, programmer, ect.
Basic bulletproof is $3500. That's EGR delete, head studs, gaskets, ect.
Chris
   / Ford 6.4 diesel reviews #15
Yes. 07 were extremely reliable. 05 and 06 was better than a 03 and 04.
Steer clear of a 03 and 04. There are actually differences in the motor and the electronics from the 05 and later trucks.
Chris
Chris
Chris
Is that a kit you buy. Around here that will buy you one that needs work
   / Ford 6.4 diesel reviews #17
Pretty sure it's in the 3k-4k range from what I've heard...Gotta get the problems before they happen though. Otherwise it ain't pretty. Once it starts dumping anti-freeze into the motor, all bets are off.
Chris
Are the 07 reliable from factory or after getting bullet proof
Trust me i know that. But i didn't know the price to bullet proof
   / Ford 6.4 diesel reviews #20
That's the Kit and labor. I know 2 guys who just bought 6.0L trucks. One was a die hard GM guy. Got a 07 F350 Dually. The other upgraded his 2001 7.3 F250 to a 07 F350 SRW.
Both got them basic bullet proofed for under $3500 total.
Chris
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
1998 PETERBILT 377 MIDROOF SLEEPER (A58214)
1998 PETERBILT 377...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
CATERPILLAR CB13 SMOOTH DBL DRUM ROLLER (A60429)
CATERPILLAR CB13...
