Ford 6.4 diesel reviews
   / Ford 6.4 diesel reviews #11
I had a co worker whose husband bought one used. Something like 70,000 miles on it. They bought the high dollar extended warranty, lucky for them. It had the cab off something like 4 times, maybe more. New short block, turbos, injectors, etc. They got rid of it finally when it was running good but it was going through a regen every 75 miles. DP is correct, at least with a 6.0 you know what you need to do to fix it.
Are the later model 6.0 better then the earlier models??
   / Ford 6.4 diesel reviews #14
Are you sure they are cheap to fix??? I've owned but not bullet proofed it and put almost as much as paid for it into it
You had a bad mechanic that threw parts. $6500 will get you one heck of a stout 6.0 around here with head studs, gaskets, egr delete, coolant filter, turbo overhaul, injectors, exhaust, programmer, ect.
Basic bulletproof is $3500. That's EGR delete, head studs, gaskets, ect.
Chris
   / Ford 6.4 diesel reviews #15
Yes. 07 were extremely reliable. 05 and 06 was better than a 03 and 04.
Steer clear of a 03 and 04. There are actually differences in the motor and the electronics from the 05 and later trucks.
Chris
Chris
Chris
Is that a kit you buy. Around here that will buy you one that needs work
   / Ford 6.4 diesel reviews #17
Pretty sure it's in the 3k-4k range from what I've heard...Gotta get the problems before they happen though. Otherwise it ain't pretty. Once it starts dumping anti-freeze into the motor, all bets are off.
Chris
Are the 07 reliable from factory or after getting bullet proof
Trust me i know that. But i didn't know the price to bullet proof
   / Ford 6.4 diesel reviews #20
That's the Kit and labor. I know 2 guys who just bought 6.0L trucks. One was a die hard GM guy. Got a 07 F350 Dually. The other upgraded his 2001 7.3 F250 to a 07 F350 SRW.
Both got them basic bullet proofed for under $3500 total.
Chris
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
Wolverine Quick Attach Hydro. Adjust Forks (A59814)
Wolverine Quick...
2023 CAN-AM HD7 RTV (A59823)
2023 CAN-AM HD7...
2022 CATERPILLAR 330 EXCAVATOR (A60429)
2022 CATERPILLAR...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Snorkel Uno 41D 4x4 Articulating Boom Lift (A59228)
Snorkel Uno 41D...
