Everlast Welders - Welders and Plasma Cutters by Everlast
   / Everlast Welders - Welders and Plasma Cutters by Everlast #631
I purchased a cheap China 6" bench grinder at my local hardware store for like $60 and a fine 100 grit wheel which I'm dedicating to grinding tungsten. This worked fine, I chucked the tungsten in a cordless drill and was able to grind a pretty smooth tip. Dang but the tungsten gets hot with just a bit of grinding.
One odd issue with the Everlast torch, a WP20, a new tungsten is about 1/2 an inch too long for the torch I had to snap off one end.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #632
Do they give you a stubby cap with the torch? On mine I always use the stubby cap and cut the tungstens in half. No waste.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #634
Mark, I have the Everlast I MIG 200.
A nut on the regulator broke. See pics. Where can I get a replacement? 1437581286407-417020482.jpg1437581137397-1307116435.jpg
Ok. Good. Glad you got going. I was going to suggest looking at a welding supplier locally as the most expedient solution since I think those are standard type connections. (or they were).
   / Everlast Welders - Welders and Plasma Cutters by Everlast #637
Thanks. It was a standard fitting. Simple trip to the local auto parts store. No biggie.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #640
My new improved tungsten grinder.
<img src="http://www.tractorbynet.com/forums/files/welding/440590-everlast-welders-welders-plasma-cutters-btg4-jpg"/>
<img src="http://www.tractorbynet.com/forums/files/welding/440591-everlast-welders-welders-plasma-cutters-btg1-jpg"/>
How much tungsten do you grind that its worth getting a grinder like that for it?
Aaron Z
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2015 CATERPILLAR...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
