Everlast Welders - Welders and Plasma Cutters by Everlast
   / Everlast Welders - Welders and Plasma Cutters by Everlast #631
I purchased a cheap China 6" bench grinder at my local hardware store for like $60 and a fine 100 grit wheel which I'm dedicating to grinding tungsten. This worked fine, I chucked the tungsten in a cordless drill and was able to grind a pretty smooth tip. Dang but the tungsten gets hot with just a bit of grinding.
One odd issue with the Everlast torch, a WP20, a new tungsten is about 1/2 an inch too long for the torch I had to snap off one end.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #632
Do they give you a stubby cap with the torch? On mine I always use the stubby cap and cut the tungstens in half. No waste.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #634
Mark, I have the Everlast I MIG 200.
A nut on the regulator broke. See pics. Where can I get a replacement? 1437581286407-417020482.jpg1437581137397-1307116435.jpg
Ok. Good. Glad you got going. I was going to suggest looking at a welding supplier locally as the most expedient solution since I think those are standard type connections. (or they were).
   / Everlast Welders - Welders and Plasma Cutters by Everlast #637
Thanks. It was a standard fitting. Simple trip to the local auto parts store. No biggie.
   / Everlast Welders - Welders and Plasma Cutters by Everlast #640
My new improved tungsten grinder.
<img src="http://www.tractorbynet.com/forums/files/welding/440590-everlast-welders-welders-plasma-cutters-btg4-jpg"/>
<img src="http://www.tractorbynet.com/forums/files/welding/440591-everlast-welders-welders-plasma-cutters-btg1-jpg"/>
How much tungsten do you grind that its worth getting a grinder like that for it?
Aaron Z
JOHN DEERE 3033R LOT IDENTIFIER 210 (A53084)
JOHN DEERE 3033R...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
2023 G Bar K Skirted Hauler Bed (A53472)
2023 G Bar K...
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
(1) 330 (1) 300 GALLON POLY TOTES (A51248)
(1) 330 (1) 300...
2021 MACDON C3812 LOT IDENTIFIER 34 (A53084)
2021 MACDON C3812...
