Plate thickness for pintle hitch
   / Plate thickness for pintle hitch #1
bdog
Elite Member
Texas
John Deere 6130M
I am wanting to add a pintle hitch to my dump truck. I was thinking of putting a 30 ton hook but really don't plan on pulling much more than 10-15 tons though I may in the future go up to 20 tons.
I was thinking of recessing it similar to the attached photo. Is 3/4" plate (with gussets of course) sufficient or do I need to go thicker? Figure this would be a perfect job to try out my new harbor freight 120volt wire feed machine and learn how to use it.
   / Plate thickness for pintle hitch #2
This ought to be fun.
   / Plate thickness for pintle hitch #3
I would look into putting strong backs on the back side. Last hitch I built for my 1-ton Dodge I used angle iron on the backside of the safety chain D-rings.
Also do this to strengthen the web of beams.
   / Plate thickness for pintle hitch #4
IFigure this would be a perfect job to try out my new harbor freight 120volt wire feed machine and learn how to use it.
:D good one! :D
Terry
That is a really good idea. I think I will do that.
   / Plate thickness for pintle hitch #7
If you go that route, no need in welding all the way around. Just skip weld the strong backs. I like to use caulking between the welds before painting.
   / Plate thickness for pintle hitch #8
I know I can't weld for beans. I have an old stick welder and I couldn't get the penetration I needed for a decent weld.
I'd tack it together, try grinding through a few welds to see what I had before going on. You don't want a trailer busting free on the road.
Good luck. Sounds like a fun project.
   / Plate thickness for pintle hitch #9
If you have to grind into your welds to determine if they are good enough, you probably shouldn't be welding a hitch, especially one for 10 tons. 3/4" plate with even 3/8" x 2 1/2" or 3" flat bar(at 90 deg's.) would be sufficient. If you had 1/2" flat bar would add a little piece of mind.
   / Plate thickness for pintle hitch #10
I think there are a lot more folks buying better machines for welding a license plate bracket.
Sounds like you've got it worked out, as long as you don't try to run the welder on an extension cord. Hope all your eqpt arrives at the jobsite at the same time.
:shocked:
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2020 DRAGON ESP...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
