motorhome convert to pickup
   / motorhome convert to pickup
the c/k 30 frame is = a 3500 = and the 3500 only came in a 1 ton model??? this true or false????
and what I have read online, in 1990 chevrolet was using the c/k frame for the non-complete commercial fleet vehicles. And it came as a c10, c20, or c30 and also the k option being 4 wheel drive. and that is what was sold to company's like four winds rv manufactures
so what I can gather from all of this is that I have the same thing as a chevy 3500 1 ton heavy hauler pickup w/ xl extended frame
& the option to make it 4 wheel drive using parts from a k frame in the future!!!!!!!!!
Who needs gas mileage anyways??????
Request to everyone: can I have some gas mileage for Christmas?
fun project no matter which way you go !....
if you have a cab to box void , stuff in a work box to store tools and lock up other items ...
I like that idea!!!! like a tow truck tool box or gang box between bed and cab
   / motorhome convert to pickup #12
most likely a 350 not a 6.0 .....All chevy MH of that vintage were small blocks
I can only find glove box info sticker. nothing under hood at all. nothing on door jambs at all.
here is what is printed on glove box sticker:
service parts identification
2gbjg31k6L4154290
p- sch-item w/b model
s 188 0501 146.0 g 31632
c60gt5k68m40n33r6pslmvxtx88yd6zw98e282w
c7cjb8lo5na4qa3r8ttgkv73yd3yhpoiu82i9w2
GQ1k34mx1na5r6escaul5xhpyd5zq3
wa-
700u95
C60 : HVAC SYSTEM
GT5 : AXLE REAR, 4.10 RATIO
K68 : onan GENERATOR,105 AMP
M40 : TRANSMISSION, AUTO 3 SPD, TORQUE CONV VAR 1
N33 : STEERING COLUMN, TILT TYPE
r6p : not found
slm : not found
vxt : not found
x88 : not found
yd6 : not found
ZW9 : g30 extended wheelbase (according to https://www.gmheritagecenter.com/do...formation-kits/G-Van/1995-Chevrolet-G-Van.pdf )
8e2 :
82W : TRIM COMBINATION, VINYL, DK MED GRAY (W)
C7C : GVW RATING, 10500 LBS________________<<<<<<<<< 1 ton????
JB8 : 8RAKE, POWER, DISC, DRUM 10000 LBS
L05 : ENGINE, GAS, B CYL, 5.7L, 1 TBI, V8...hmmm 350... nice...
NA4 : EMISSION SYSTEM, GVW,AB0VE 8500 LB
QA3 : WHEEL, 16 X 6.0, STEEL
r8t : not found
tgk : not found
V73 : ANTENNA, FIXED
yd3 : not found
yhp : not found
01U : PRIMARY COLOR, EXTERIOR, SPECIAL, (91)
82I : INTERIOR TRIM, MED DK GRAY (91)
9w2 : not found
GQ1 : AXLE, STD RATIO
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
MX1 : MERCHANDISED, TRANS, AUTO PROVISIONS
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
r6e : not found
sca
UL5 : RADIO, DELETE
xhp
yd5
ZQ3 : SALES PACKAGE, DRIVER CONVENIENCE II
thank you K7LN for helping me with the missing rpo codes below!!!
r6p = Sales control item
slm = Sales processing stock item
vxt = Vehicle - incomplete
x88 = Market brand - Chevrolet
yd6 = Spring rear Base equipment
8e2 = Front seat delete
r8t = Sales control item
tgk = Color combination - solid, special paint
yd3 = Axle (base equip) for scheduling GVW plate
yhp = Tire rear - LT225/75R16/D BL R/PE ST TL ALS
9w2 = Color - polar white
r6e = Sales control item
sca = Plant code - Scarborough, Ont, Canada
xhp = Tire front - LT225/75R16/D BL R/PE ST TL ALS
yd5 = Spring front - Base equipment
   / motorhome convert to pickup #14
Subscribed. I want to see how this turns out. :)
to remind myself,
I measured 166" wheelbase center to center +/- 1" for brothers lack of knowing how to hold a friggin tape measure tight!!!!
also 8 lug 6.5" bolt pattern front and rear.
and g30 according to the rpo sticker
and gvw 10500
does this make it a 1 ton 3500?
when the downpours stop here in tampa florida for more that 2 minutes, I will get the sawzal and start cutting!!!!
   / motorhome convert to pickup #16
I have seen one of these running around where I live. Like someone else said, building the back wall of the cab is going to be the hardest part. The bed is easy, I would make a flat bed for it.
   / motorhome convert to pickup #17
you might get a few bucks more out of fridge, sink, stove, generator if there is one some place on it, maybe A/C unit as well via craiglist battery bank / charging system might be nice to keep and/or sell.
the water pump for sink/shower, you might be able to re-use as a "12v electrical sprayer pump"
   / motorhome convert to pickup #18
Steve:
I only hope you have some young children to embarrass when you pick them up after school in that thing. I once had a decrepit Isuzu SUV that smoked so bad that my daughter would walk two blocks from school to be picked up so her friends would not see her get in it.
   / motorhome convert to pickup #19
Go for it. I'm looking forward to following your progress
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
Quick Hitch Skid Steer Attachment (A56860)
Quick Hitch Skid...
New/Unused Stand on MX-MRW14 Wheel Loader (A57453)
New/Unused Stand...
Forklift (A56857)
Forklift (A56857)
J and L Cargo Express Shadowmaster Enclosed Trailer (A56436)
J and L Cargo...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
