New, compact counterweight w/2 in sq reciever about 800 lbs (cost was less than $20 BTW) + Wheel weights 360 lbs (cost $378) + loaded tires 480 lbs. Total 1640 lbs.
Works for me, for what I do. Different tractors react differently. Obviously your mileage may vary.View attachment 289870
Recently, I was using my L3540 to do some excavating and dirt moving. I had a heavy skid-steer bucket (500+) and had no issues with moving full loads of dirt with just my snowblower for ballast (600# 'ish). Even when I overloaded the bucket in a gravel pile and couldn't lift it, my rear tires stayed firmly on the ground. I do benefit from living on the Canadian Prairie which is pretty flat so stability isn't the same concern for me that it would be for many others.
First, do you have loaded rear tires?
Second, anything in the form of a 3ph attachment makes better use of its weight than a ballast box. Simply because the weight is farther back. 600# that is centered 30" back in the form of a blower does WAY more good than 600# in a box that is in close.
k0ua, the 3pt attachment is off of a junked Bush Hog cutter, The 2 big chunks of iron on the bottom were given to me. I think they were part of a counterweight on a electric fork truck. Between the 3/8- 3X3 angle are two pcs. of 2 X 3.5 in. steel that I had lying around. I welded the reciever to them. The 5/8 rod was just overkill in case I need to lift a lot on the reciever. I thought about more bracing, but figured I'd see how it goes. When I get around to it, I'm going to add a basket to carry chains.
I liked some of the ideas expressed on the forum by you and others, who had attached tool holders or hitches on their counterweights. I felt that with this design I could easily weld on whatever I need in the future. If the addition was temporary I could attach it to a 2X2 sq. tube and slide it in the reciever. I guess it's a design in progress.:scratchchin:
You got any good ideas on improvements? I'd like to here them if you do.:listen:
Best, Bill
The first thing I noticed that I liked about your design was you weight is down low keeping the center of gravity of the tractor low.
Our L3240 with LA724 FEL is the replacement model for the L3130 and very similar to what you have.
For FEL work, I like to have either the 760# box blade or the 600# tiller on the 3pt.
I don't have loaded tires or wheel weights, but I do have a backhoe sub-frame, which helps.
With the ballast described, I haven't had any rear wheel lifting or shortage of traction while moving full buckets of gravel.
... Just realized I was responding to a 3 year old thread. OW. The information is still good for anyone with a similar question.
BTW - I really like Notforhire's ballast implement. V-E-R-Y low CG should help stability on side hills and the receiver hitch makes it even more useful.
I buy pallets of coal, which weigh 2,400#.
I might as well respond to an old thread too.
I am surprised you find that ballast sufficient. but then again, a full bucket of gravel maybe 1000#. Not near your max by a good bit. If you latched onto something immovable, I am sure your rears would lift before the loader went into relief. Even just trying to break out of a dirt pile, or dig stumps I would think you would have issues.
700# blade on my weaker loader AND loaded tires is a good match. But with curl I can still lift the rears.
Coal?! Cool.
2,400# is pretty stout.
I have a 3500# pallet of retaining wall blocks that hasn't moved since it was dropped off (leftovers from a large project) several years ago. Nothing I have will touch it.
3pt forks is really the best solution for lifting heavy pallets enough to move them.About 25-30 yrs ago I built a set of forks that went on my 3PH. You couldn't load a trailer, because of the limited lift, but it was good for moving things like your pallet of blocks.
In the interest of not going off topic, if you lifted those blocks on the 3ph, think of the dandy counterweight they would make.![]()
Or he could get an empty pallet and move half the blocks onto it.
Or he could buy a larger tractor, as a more fun, but slightly more expensive solution.
