Adding a winch to 7 ton trailer
   / Adding a winch to 7 ton trailer #1
Happy Gilmore
Southeastern, MA
Ford 5610 Ford 4630 Ford 3930 MFWD w/ 7310 loader Ford 3930 Kubota BX1500 Kubota RTV 900XT Kubota F2680E 72"RD Ford 4610 Kubota KX121-3
I am thinking about adding a winch to my Cam Superline 7 ton 20' full tilt deck over equipment trailer. I've got a friend suggesting a Warn M12000. It will be a general use winch depending on whatever situation may arise. Any thoughts?
   / Adding a winch to 7 ton trailer #2
Well you can never go wrong with a Warn. Best quality out there however, a premium you pay for. I have a M12000 and Warn Powerplant HD at the house. Both good machines.
These days you can get cheap winches made in china for a fraction of the cost. I put a Engo 9K on the rear of my jeep. You are only using it on a trailer so life saving recovery nor cable length is an issue. You can always us a snatch block and double the rating of the pull. I'd have to go that route if I wanted a winch on my flatbed trailer.
Maybe if you can get a good deal on a used Warn the price could be justified. Many times the off-road type people buy and then sell a winch.
   / Adding a winch to 7 ton trailer #3
I agree with CC. The Warn is an excellent winch but for something that is going to sit on my trailer, in the weather, and only be used a half dozen times a year I bought a 9K winch from tractor supply for my 14K PJ full tilt trailer. I have a snatch block and several hooks and frame connectors.
   / Adding a winch to 7 ton trailer #4
I went cheap also. I got a 5000# winch on Amazon for $130 delivered. It's pulled tractors as large as a 900 Ford, a Suburban, a Silverado, and numerous mid sized cars without issue.
Chris
   / Adding a winch to 7 ton trailer #5
I've always used Warn winches. Never had a moments problem with them. All were mounted on the front of a 4WD vehicle - one Bronco & two Jeeps. Now, as far as batteries, that is a totally different story. Under extreme and near continuous use, you can go thru batteries like a kid eating candy. You will probably never be in a position like that, so a heavy duty battery will suffice.
   / Adding a winch to 7 ton trailer #6
Mount it on a receiver winch mount like this, so it can be used on your truck or tractor also.
437868-adding-winch-7-ton-trailer-p6090002-jpg
437869-adding-winch-7-ton-trailer-p6090009-jpg
437870-adding-winch-7-ton-trailer-p6090012-jpg
437871-adding-winch-7-ton-trailer-pa012378-jpg
437872-adding-winch-7-ton-trailer-pc312025-jpg
   / Adding a winch to 7 ton trailer #7
The receiver mount is a great idea. Check out viper winches. I have the 12k model and the price was very reasonable. Make sure you get a good battery and figure out a way to keep the battery topped off if you don't tow often. A solar charger or a trickle charger that plugs in would be a good idea!
   / Adding a winch to 7 ton trailer #8
Xfaxman - in the bottom pic. Were you stretching that pickup and making a crew cab - ha,ha. Looks like the Massey must have been connected to the back of the pickup. Those "receiver hitch" Warn's look to be VERY handy. Warn didn't make that type when I used their winches.
   / Adding a winch to 7 ton trailer #9
I just plug into my truck to operate my trailer mounted winch ( 8K ramsey).. No need to buy maintain an xtra battery
   / Adding a winch to 7 ton trailer #10
Do you have large guage cables from your battery to the back of your truck. Just wondering how you power up the trailer winch while the trailer is hooked to the truck. Or, are you talking about two vehicles?
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2019 CATERPILLAR 259D SKID STEER (A60429)
2019 CATERPILLAR...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
