Brand new XJ2025h and already have a cut hose and hyd leaks?????
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #11
Definitely an issue on the J2023 as well. Just checked mine & it is down to the metal. I contacted my dealer & informed him for future reference. A couple of repair ideas would be lengthen the hose & then feed all 3 through a larger braided hose. Have to give thanks to you cvcman. Don't feel too bad for your misfortune because for some guys this may not be covered under the warranty. This hose may be considered a loader part & only carries a 1 year warranty. This is TBN at its finest. Thanks again cvcman.
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #12
When I first got my tractor I repositioned my fel control and moved my hoses to do so.
I put a tie around hoses and bent floor pan to give me more clearance.
I now see by looking at pics online of other Ls tractors...MOST of the ones I see have the hose routed outside the mounting plate so it would be pleanty long enough.....this should NEVER have been sent out like this....what tranny oil should I use to top off ????
when I get the new hose im going to chg it and zip tie the three together that go to the rear and make sure they are not going to get caught on anything or hit the tire...
this is how the others look...mine the hose runs behind the controlls2025.jpg
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #17
once I get my new one on im putting that flexable plastic wire loom over the hose where it touches the frame...The larger New Hollands don't have all these hoses this long...much nicer neater system.......
Hey guys, I don't see any grease fitting on the tractor itself, is this right ???
Also what tranny fluid are you guys using
Yes, Murph that was done before I moved things and the reason I put a tie on hoses and bent floor pan.
Cheers
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #20
Disregard the advice I suggested about wrapping your lines & do just as BLUE ME suggested. Just move the top hose to the inside (closest to the hood) & move the loader valve to the most upright position. Bending the floor pan isn't necessary. Like he stated, also gives you more room to enter from the right. 2 for 1.
UNUSED WOLVERINE PT-16-01C UNIVERSAL ADAPTER (A51248)
UNUSED WOLVERINE...
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2017 Ford F-150...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
