Brand new XJ2025h and already have a cut hose and hyd leaks?????
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #41
You will want to us a Hy-Tran oil.
It has higher pressure ratings. Regular universal hydraulic fluid will not hold up between the gears in your transmission.
I. Called Ricky Marks at LS. Direct...he said "any 10 weight hydralic oil,thats what they leave herehere with"
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #43
Mine were ziptied to the black support bracket, but they were rubbing there as well. So, either wrap them w/something or you will need to relocate them.
well got my new hose and this one is a much nicer heavier hose ....3" longer.....rerouted so I can swivel the handle on the bracket...anyone have a pic of how they are fastened under the floor pan ??
[/QUOTE]
yea I put a pc of plastic wire loom on each hose and re-zi tied it to that same bracket
[/QUOTE]
[/QUOTE]
   / Brand new XJ2025h and already have a cut hose and hyd leaks????? #46
this is an old thread but I sure am glad I ran across it.
I happened to read this the day before my tractor was delivered by the dealer owner. When he was going over some final checks, I pointed out the hose location and the chance for it to get cut and his thoughts were to put a extra wrap of heater hose or something on it to protect it rather then run the hose on the outside.
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
NEW Fork Extensions (A53002)
NEW Fork...
New Long Forks (A53002)
New Long Forks...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
1992 Peterbilt 377 Sleeper Cab (A53472)
1992 Peterbilt 377...
JLG 1930ES ELECTRIC SCISSOR MAN LIFT (A51246)
JLG 1930ES...
