JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 3,995
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
Several points: I own a MF 2660 HD low-profile bought new in 2011. 1) The 2650/60/70 "HD" series was absolutely made in Brazil. Not India or somewhere else. 2) The 2660 had a horrible first 100 hours. Met every definition of a lemon. You name a type of problem and I'll describe in detail how it happened on my 2660. I was right on the edge of selling/trading it in 2014 when I got (I hope !!) the last few bugs out of the thing. Since then it has been great and one of the best tractors I've seen.Quick search on tractor house of 2014 and older 4608, m7040, m7060, 5075e..4608 had less used for sale..John Deere having the most so by your logic John Deere sucks worse than Massey or Kubota.
Can you point me in the direction to these claims of people having issues with the 4608? I searched and can't find anything. I've found pleanty on the 2600 series which made me not even look at Massey when I first started looking for a new tractor.
And Massey isn't cheaper than Kubota. To begin with Kubota was about 3k less than Massey. John Deere was about 4k more than Massey. I'd have to say the major brand where all within about a 5k price difference. I priced Kubota Massey case new Holland and John deere
Back to the 4600 series: (1) The initial most frequent complaint that I found was weak steering. If you had a heavy bale on the front end trying to steer in mud it would not turn. Of course that COULD get bad with any tractor. However, I know one dealer who felt it was serious enough that he refused to accept any more from the factory until they resolved the issue. I hear that later serial numbers had something done for more robust steering. I also know one owner of an early 4608 who says "yeah, the steering should be a little stronger but just move a small amount before turning and it is no problem." (2) The power shuttle shifter on his 4608 would darn near tear up his implements and other things going fwd to rev to fwd. That was adjusted out of it by the dealer. Fixed. I have heard very little wrong/bad about the 4600 series. You probably know but there are several things better about your 4608 compared to the larger 2600 series made in Brazil. First: Bevel gear FWD is much more maneuverable (as is the Kubota.) Second: the power shuttle transmission SHOULD be great if it turns out to be reliable. Third: The wet clutch necessitated by the power shuttle SHOULD be better. Fourth: Made in Japan. I do not think you will soon see Brazilian made MF tractors sold in the USA after the debacle many had with the 2600 series. Things that never should have been let out of the factory. Fifth: You have a better choice of loaders (I hope you got the 931 or at least the DL260. I'm stuck with a DL250.) I'm really happy now with my 2660 but can tell many horror stories about getting to that point if anyone wants to hear them. Hope your 4608 is reliable and enjoyable. It should be !
