How do you store a chainsaw so it will not leak bar oil.
   / How do you store a chainsaw so it will not leak bar oil.
My wife bought battery operated limb saw with about 8" bar. It looks like a flimsy toy but I was surprised at the power. It will cut 8" limb about as fast as my Husky.
   / How do you store a chainsaw so it will not leak bar oil. #32
I bought one of the Harbour Freight cheapies and it works great. I was really surprised. My dad has a Remington and its appears to be a lot better built than mine but I've been using it for 3 years now and it still runs strong. The Harbour Freight saw doesn't have a chain brake on it not sure how they get away with that nowadays with all the crazy lawsuits. Wouldn't be afraid to buy another one when this one dies. Its a 14" and yea it leaks oil if not hung up so I guess that means it's working right and oiling when it suppose to.
   / How do you store a chainsaw so it will not leak bar oil. #33
My saw leaks very little oil. I keep a shop towel in the bottom of the case. As long as the oil is coming out of the right hole I don't worry about it.
   / How do you store a chainsaw so it will not leak bar oil. #34
I have Husqvarna, Echo, McCulloch and Remington electric. All leak bar oil.
Buy a Stihl, I did, and it's the only saw I ever had that didn't/doesn't leak oil or gas.
That's all I got, except there are some good points about putting it up empty too, though I don't knowchow to choreograph that for mine.
   / How do you store a chainsaw so it will not leak bar oil. #35
I miss the old saws with the pump just pump the oil you need. Never have liked or trusted the auto oilers but i guess they're here to stay.. Gotta change with the times.
   / How do you store a chainsaw so it will not leak bar oil. #36
My favorite saws are from the 80s, and they sometimes have BOTH.
Anyway, many of the older saws have plain oil tank vents, rather than newer ones with
check valves (often so-called duckbill valves) to allow air into the tank, not out. That
could cause a pressure buildup in the tank, but that may be due to temperature
variations. Using the saw would not allow pressure buildup.
If you DO get pressure buildup, you can certainly cause a leak. Just seasonal
barometric changes in your shed can cause this buildup, too. Cracking open
the oil cap is one solution.
   / How do you store a chainsaw so it will not leak bar oil. #37
Never thought about it maybe building up pressure and forcing the oil out. I'll crack the cap a little next time and try it. It's not really a big deal anyway but a few drops of oil goes a long way in the bedliner of my pickup.
   / How do you store a chainsaw so it will not leak bar oil. #38
All of my Stihl caps have had vent holes in them. Dealer says to run them out of oil/gas or they will leak, but I carry one on my tractor and find an empty chainsaw is about as good as an empty gun.....
   / How do you store a chainsaw so it will not leak bar oil. #39
yeah, what do you do if your done cutting and still have half a tank?
   / How do you store a chainsaw so it will not leak bar oil. #40
Well-put, Pat.
The same dealer will say, "buy another chainsaw".
If you like the guey kind of oil, try draining that out. Yuck. I don't use that, and
rarely even run one dry.
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2021 CATERPILLAR 262D3 SKID STEER (A52705)
2021 CATERPILLAR...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
