Mosin-Nagant hex receiver
   / Mosin-Nagant hex receiver #21
post a pic ( or email me one ) if you can.
Have you looked on gunbroker for a bbl?
finding one for a m39 will be tough.. not may people parting those.
in the end.. you might be money ahead to sell that one and buy a cheap variant, type 53, 91/30, etc... if you are looking for a shooter.
Here is a picture of it. It's hard to get any pics of barrel markings. It's pretty ugly, guess I just got a bit over excited when I found out it wasn't just a regular production M91/30.
   / Mosin-Nagant hex receiver #23
you can always look under the tang for a date and hammer symbol ( tula )
poor thing has lost it's wood....
So, I was playing on Gunbroker.com app; and found several barreled receivers of M91/30; several for cheaper than just a barrel. Would my bolt, magazine, trigger group just drop into another (round) reciever, buy a $49 stock and save the hex reciever for "one of these days" project?
   / Mosin-Nagant hex receiver #25
the m39 could have a improved 2 stage trigger, and better disconnector / seperator for magazine usage.. but if the stock has shims, it's a fitted part. mixing and matching may get you rim lock. also.. there are minor mods to fin'd bolts and to the feed ramp area at the rcvr.
I would NOT look to mix and match parts...
if you want a cheap mosin variant shooter.. buy a cheap mosin variant shooter.
m39 wood, as you will notice, looks very very different than any other models wood.
could you repurpose another stock and make it work? probably.
   / Mosin-Nagant hex receiver #27
Think my first mosin was 39$
   / Mosin-Nagant hex receiver #28
Hello,
That's not an M39. Though it's hard to tell what it is from that pic, it's likely an M24, M27, or M28. The M28/30 and later don't have dovetail rear sights, and I'm pretty sure I see a dovetail on there. The M39 has a pistol grip wrist, not a straight wrist.
What's the front sight look like?
It could be I'm mis-seeing things due to the blurry pic.
This thread is what got me here, so I'll follow it.
Regards,
Josh
   / Mosin-Nagant hex receiver #29
See the different models in my post #12 above.
Hello,
Regards,
Josh
The front site is gone, it was part of the barrel that was cut off. The main reason I came up with the M39 was the 1942 Belgium barrel, the 7.62x54 (not 7.62x53; D stamp). The rear site was hard soldered I think but I'm not looking at it right now, so I'm not 100%
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
500BBL WHEELED...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
