?? NAA Lift Arm Pivot Stud in axle housing spinning
   / ?? NAA Lift Arm Pivot Stud in axle housing spinning #71
I like it. Nice job.
   / ?? NAA Lift Arm Pivot Stud in axle housing spinning #72
The back blade comes in handy for backfilling and grading around the pole building also spreading gravel.
I know sometimes they are put back into service before they are really done but when there's work to be done these little fords got to step up to the plate and Get R Done.
Kirk
Thanks! It certainly looks better, but I'm sure, in a show, there would be many things, which would receive criticism. I guess, the biggest thing, would be the sheet metal, as it had many spider cracks, welds, dents and dings, etc.. I did quite a lot of welding to the cracks and some body work, but in some cases, it was nearly impossible to tell what needed to be done.
The back blade is probably second to the brush hog, in use.
   / ?? NAA Lift Arm Pivot Stud in axle housing spinning #75
Glad to see you getting some use out of it. Looks good. Hopefully I'll get mine out in the yard and cause some terror
2013 Nissan Rogue SUV (A51694)
2013 Nissan Rogue...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2011 Toyota RAV4 4x4 SUV (A51694)
2011 Toyota RAV4...
