5 ft rotary cutter choices
   / 5 ft rotary cutter choices #21
The KK light duty cutters have terrible hitches. Too light, same with the light metal straps back to the tail wheel.
Pick the cutter up and you can see the whole thing flex.
I've had a King Kutter 6' cutter for years. Never a problem with it. Never saw it flex.
It is twice the cutter of my previous John Deere 513 cutter was.
   / 5 ft rotary cutter choices #22
Is that a standard KK version?
The "professional flex hitch" and Heavy duty versions are different.
The standard ones with just the thin 2" by 3/8" or so bar straps that form the A-frame, and two even lighter 2" straps that anchor back near the tailwheel.....those flex alot.
IF you have that type, you may just not be noticing it. Raise the cutter and then go use a little body weight and bounce the tail wheel a bit. You will see all kinds of flex.
KK ist the only light duty cutter I have seen with the light A-frame. Its actually hard to fine a used cutter with this type of setup that isnt bent somewhere on the hitch.
   / 5 ft rotary cutter choices #23
Slip clutch. It takes about 15 minutes once or twice a season to set it to the proper tension.
   / 5 ft rotary cutter choices #24
I have a KK mower and the hook up and tail wheel metal is not strong enough for rough treatment on uneven ground. I love the way it cuts and highly recommend it for light duty pasture work. If you are using it for the tough stuff, you will not be as happy. I like the shear bolt for a smaller(5 foot) cutter.
   / 5 ft rotary cutter choices #25
agreed. service it at least every season and should be good to go.
   / 5 ft rotary cutter choices #26
Here is the EA underside of rotary cutter. That stump jumper doesn't look very tough....
I agree, the photo shows no depth or definition. It does show that the deck is welded underneath. If you look under a Land Pride, they do not weld the joints under the deck.
Here are photos of the stump jumpers that we use.
They are 20" diameter and 1/4" according to my tape measure.
Travis
Stump jumper for 45HP gearbox. 31 pounds
Stump jumper for 75HP gearbox. 39 pounds
Travis
View attachment 444497 View attachment 444498 View attachment 444499
View attachment 444500 View attachment 444501 View attachment 444502
Thanks so much for the stump jumper photos. Clarifys alot !
   / 5 ft rotary cutter choices #28
I looked at Bushog, Land Pride and Woods 6' rotary mowers today. If I were buying again I would buy Woods. Still seems to be the best made mower. Mine has never caused or had any issues.
   / 5 ft rotary cutter choices #29
Travis
Looks pretty tough to me. I bet it will more than do the job. I think a rotary cutter is one of those things that you can buy by weight. A 600lb cutter is better than a 500lb cutter and so on. Less vibration and more durable. They are not all that complicated. You do need a bigger tractor with a heavier cutter.
Ok folls...i have made a mistake and glad i caught it. I do have a 28 hp tractor but the pto hp is only rated at 22 hp. Was going to get the Woods BB60X but it requires a 25 hp pto min. So i must down grade to the lower model. Was looking at the Kodiak but i see where they were bought out in May of this year. So now will look at the Woods HC60.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2006 Reelmaster Toro 3100D Mower (A50324)
2006 Reelmaster...
2002 John Deere 110 Backhoe (RUNS) (A50774)
2002 John Deere...
International 140 Tractor (RUNS) (A50774)
International 140...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
