Bush Hog Connecting PTO shaft
   / Bush Hog Connecting PTO shaft #51
Here is a link to it at Surplus Center. They call them both "sliding collar" style. https://www.surpluscenter.com/Power-Transmission/PTO-Shafts-Jack-Shafts/PTO-Shafts/1-375-DIA-6-SPLINE-W-SLIDE-COLLAR-TRACTOR-YOKE-1-3720-C.axd As I noted, I have all three types but, probably prefer the sliding collar with large flange. They all work IF you keep them clean and lubed. I think the cover over the yokes is part of the issue as it makes it difficult to get your hands around the yoke. Another issue with me is the Delta Hook QA I have to work around. The Woods cutter has my least favorite type yoke. <img src="http://www.tractorbynet.com/forums/files/attachments/445172-bush-hog-connecting-pto-shaft-image-3290370346-jpg"/> <img src="http://www.tractorbynet.com/forums/files/attachments/445173-bush-hog-connecting-pto-shaft-image-2577203573-jpg"/> <img src="http://www.tractorbynet.com/forums/files/attachments/445174-bush-hog-connecting-pto-shaft-image-2588269898-jpg"/> Sent from my iPad using TractorByNet
Also, to further complicate hookup, the metal guard around PTO on my LS XR4046HC doesn't swing up like same on my New Holland TL100A.
   / Bush Hog Connecting PTO shaft #52
I totally agree with Rick. I have the "easier" flange/collar type as OEM on my Bushhog 286. It MIGHT be easy to attach by holding the shaft and yoke between the butt of your palms while holding the flange back with several fingers on each side, EXCEPT that the big plastic bell end of the shaft cover prevents you being able to grasp the shaft between your palms and still be able to fit fingers in. Clearly, whoever designed the lock collar was NOT coordinating with the shaft cover designer! Two designs done in complete ignorance of the other.
I really do like Erik's bungee helper method. Will have to try that!
- Jay
   / Bush Hog Connecting PTO shaft #53
- Jay
Well I sorta agree. I haven't tried it that way. I might try it at some point.
But what I have done is not hook up the top link and bungee cord it back to the tractor so I can step over and above the drive shaft.
- Jay
That's why I suggested the screwdriver to push the yoke forward as one uses their other hand to pull back the collar. It works well. And a bungee holding the shaft at the right height can't hurt make the whole nightmare less of one...
   / Bush Hog Connecting PTO shaft #55
By Far the worst implement that I have with the stupid pull back collars is the PHD! :mad: There is absolutely zero room to get between the tractor/phd. I usually wind up just about laying on the ground under the shaft and still fighting to get it on. Those **** pull back collars are of the freaking devil. :(
2016 Ford F-150 Pickup Truck (A51692)
2016 Ford F-150...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
