tooth bar question
   / tooth bar question #1
bama21fs
jacksonville, alabama
john deere 1025R
I have a JD 1025R and I am looking for a good, economical, aggressive type tooth bar to put on my bucket. My problem is that there are so many companies out there making tooth bars, I do not know which direction I should go. Does anyone have any recommendations. Please advise
   / tooth bar question #2
Prepare for about a dozen recommendations for a ratchet-rake. :confused3:
And another dozen for a Paranah (sp?) serrated bar.
Both very useful tools but neither a tooth bar.
   / tooth bar question #3
   / tooth bar question #4
I'm not sure good & economical go together. It may depend on what your primary use is going to be?
I use the Bxpanded piranha $300. It's pretty good at digging, but is better at clearing brush. Some with longer tines might be better at digging. There's tooth bars and just teeth that bolt on.
Do a search for tooth bars, there's lots of threads on them
   / tooth bar question #5
WR Long is a good place to start for a real tooth bar (i.e. for digging in undisturbed soil or sod).
   / tooth bar question #6
I agree with luke - you can't go wrong with WR Long for a good and aggressive tooth bar. It is not cheap but it is worth the money if you need one. I got mine thru Everything Attachments.
gg
   / tooth bar question #7
Yup, WR Long is a good one, as is Tisco, which is what I use on my 72" bucket on my larger tractor. Similarly priced. For aggressive digging in difficult conditions, a real tooth bar like those (i.e., with individual, extended teeth) gives better penetration that the Piranha bar because the point loads on contact are greater. The teeth also extend farther beyond the cutting edge of the bucket, so they give more support when trying to handle logs longer than the bucket's width. There are definite trade-offs, though. The tooth bar won't cut through brush like the Piranha when clearing, won't back-drag as smoothly, and I think is more of a hindrance than a help when trying to move snow if you leave it on all year.
Actually, how much serious digging do you think you'll be doing with your tractor? If it's only occasional, I think I'd be inclined to recommend the Piranha for a SCUT your size because of its versatility.
   / tooth bar question #8
Don't do a half job.
Get a real tooth bar and you will think you have a new machine.
A tooth bar will do everything a ratchet rake will but the inverse is not true.
   / tooth bar question #9
titan has a tooth bar also reasonably priced, just ordered one delivery set for next fri will have some updates then, about to order a titan quick attach 3point adapter also
   / tooth bar question #10
Mine came from Iowa Farm Equipment. They ask you to measure your bucket to insure you get the best fitting one they have. They are easy to put on/off and make a world of difference when moving materiel. Check them out;
Iowa Farm Equipment -- Bucket Toothbars & Cutting Edges
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
