Why does everyone rant and rave about the EcoBoost?
/ Why does everyone rant and rave about the EcoBoost? #41
Just a thought, wouldn't a weep hole in the IC cause a loss of boost to some degree? One of the tests I do to commercial trucks annually is a pressure test on the IC. Remove both side pipes and hoses, seal up, and pressure to 35 PSI with a gauge. If the IC looses 5 PSI or more in 15 seconds, time to replace. This type of loss greatly affects power and economy. Seems strange to punch a hole in the system and negate what it is supposed to do.
/ Why does everyone rant and rave about the EcoBoost? #42
I really don't know except modifying anything remotely emission related in California can get you in serious trouble...
So i take it very few are interested in burning corn (ethanol)?
/ Why does everyone rant and rave about the EcoBoost? #44
/ Why does everyone rant and rave about the EcoBoost? #45
Before the EPA jumped down everybody, all factory intercoolers had weep holes. To the best of my knowledge, I was the first to tell people to drill a weep hole in the intercooler to blow out moisture and avoid hydrolocking the engine and misfires that started happening in 2011 with the then new ecoboost.
After people asked me about pressure loss since over a 1/16" hole I finally made this video.
Ford cannot just drill a 1/16" weep hole at the bottom of their intercoolers to solve the on-going water-vapor misfire problem, but you can.
The Result: at idle there is insufficient volume to develop any notable pressure. However, the big idea is if a 1/16" weep hole drilled at the lower left front corner of the intercooler to solve the misfire issue ever draws vacuum, and it does not. As a result, I wouldn't worry about a weep hole at the bottom of the intercooler unless one is crossing a flooded road or doing water crossings. In those conditions, a nipple should be installed, and a breather line popped on that vents at a higher place.
/ Why does everyone rant and rave about the EcoBoost? #46
Ethanol and forced induction don't mix well together. In my Boost I run 93 octane to get the most performance (the computer will compensate for the increased octane by advancing the timing resulting in an increase of 15 hp and 40 ft-lbs of torque) and better mileage. Once I'm out of warranty, and assuming I don't trade early for a diesel, I plan to install a tuner which by all reports will turn it into a screamer.
/ Why does everyone rant and rave about the EcoBoost? #47
The weep hole is 1/16" so you're not getting significant pressure loss. Just enough to allow any moisture to fall out. I saw zero loss of boost by installing the hole. And as Eric pointed out, at no time is the IC under vacuum to pull anything into the cooler.
/ Why does everyone rant and rave about the EcoBoost? #48
One of the knocks I've heard about the Ecoboost is the potential for fuel in the oil. Apparently a problem that can happen with all direct inject engines. My buddy did an oil analysis and the report came back indicating 6% fuel in his. The dealer replaced the PCV with a new design and reflashed the computer. The reflash apparently makes the engine run leaner during warmup, reducing the oil contamination. A subsequent oil test showed the problem was fixed.
I have 30K on mine and will do an oil analysis on the next oil change.
/ Why does everyone rant and rave about the EcoBoost? #49
Good question. They have had several fixes over the years with varying degrees of success. The 2 most successful aftermarket solutions are a catch can, which is basically a separator for air and vapors, and the weep hole. I have a weep hole on mine which has been there since the week I got it home. There's definitely a residue below the location but I haven't experienced any issues as it blows any crud out the hole.
Actually, they move the blow off valve to the intercooler so the problem solved it's self.
/ Why does everyone rant and rave about the EcoBoost? #50
Yes. And every one I have seen parked has had a sooty tailpipe. They run rich.
Guess it's a direct injection thing. Mine will actually trail black smoke in the morning when I back up. Can see it in the mirrors. These engines are also prone to "gaining" oil in the cooler months from fuel getting past the rings. Several times mine has been 2 quarts over full when the 10,000 mile oil change comes around. Having replaced the timing chain twice and phasers once, I'm now doing the oil changes at 5,000 miles.
/ Why does everyone rant and rave about the EcoBoost? #51
The BoV is on the intercooler now? Is this on the new models from the factory because that's the first time I've heard that.
Also are you saying you change your lube oil at 10k mile intervals in your Boost?!? If that's the case I pity the sucker that buys the truck after you've had it.
/ Why does everyone rant and rave about the EcoBoost? #52
When I bought my 2012 the dealership told me more than 3 times to do 5K oil changes.
It does not gain any noticeable oil.
Chris
/ Why does everyone rant and rave about the EcoBoost? #53
My family had been in the car business or decades... one thing they always stressed is early oil changes are a small price to pay...
My 85 and 91 Silverado work trucks work hard... but don't travel far... mostly just in town.
Since day one I have changed the oil every 2500 miles which works out to be every 6 months...
I have commuter friends that are able to stretch to 7,500 miles which also works out to be 6 months.
Could be why we have all experienced longevity... one gal has over 300k on her bought new Honda Accord... no engine or transmission work... she drives dailey from Oakland to Stockton and back to Oakland each work day...
/ Why does everyone rant and rave about the EcoBoost? #54
I have not driven an ecoboost pickup, but we do have a 2014 ecoboost Escape SE with the 2.0L engine. We bought it on 6/23/2014 with 16175 miles on it. It had been an Oklahoma rental car. We have put a little over 20k miles on it ourselves; absolutely trouble free so far. Mileage on individual tanks of gas has gone more than 28 mpg with several over 27 mpg, but since most of our driving is short distances locally, using the air-conditioner, our overall mileage since we've owned it has been 24.685 mpg. It's supposed to have the system that will tell me when it needs an oil change, and may go 10k miles supposedly, but I just can't bring myself to let one go that long, so the oil change light has never come on, and I let the dealer change the oil & filter at 5k miles.
I think it's the dandiest little car I've owned, plenty of pep and power, good handling, and all the bells and whistles I'd ever want. Of course it may die tomorrow, but so far, so good.:laughing: I'll probably replace the original tires early next year.
/ Why does everyone rant and rave about the EcoBoost? #55
How? The intercooler is not part of the emissions system. The weep hole at one time was a recommended fix for the condensation issue from what I've read and it works and has zero chance of causing a failure as it is never under a vacuum at idle and pressurized at boost.
Drilled mine and posted videos on how much water came out. No problem to drill. The reason for emission concerns is that there is small amounts of oil in the water from case ventilation.
I agree with everyone about the noticeable power difference. In fact it is probably quicker than most 6 liter class motors. I average 15-16 in town and around 18 on the interstate. Towing milage is probably worse than the 5 liter but holding 6th gear cresting hills makes me grin.
/ Why does everyone rant and rave about the EcoBoost? #57
I performed tests to see for myself. Watch my videos.
Boost pressure with and without hole.
https://youtu.be/FFSQT1ALRak
Why I drilled
https://youtu.be/QXP1KBXSny8
/ Why does everyone rant and rave about the EcoBoost? #58
Chris
I do the same. No oil gain.
Dilution issues are more a problem in colder climates. Ford recommends block heaters for those reasons. This is true with any direct injection motor. Not just Ford.
/ Why does everyone rant and rave about the EcoBoost? #59
Man I would love to get 14-15 MPG. I barely get 12 in the Commander - without towing anything. Voracious.
OUCH- I just managed 16.8 hand calculated pulling my 10 K 20 foot fifth wheel trailer loaded with an older John Deere 3 bottom hydraulic lifted plow pulled with my 03 Cummins powered 1 ton 4x4 RAM delivered it and made the return trip- total of over 300 miles. have broken 24 with just the wife on hiway shopping trips in the city.
the Commander you have, one of the new Jeep designed vehicles?? Gas powered?
/ Why does everyone rant and rave about the EcoBoost? #60
Drilled mine and posted videos on how much water came out. No problem to drill. The reason for emission concerns is that there is small amounts of oil in the water from case ventilation. I agree with everyone about the noticeable power difference. In fact it is probably quicker than most 6 liter class motors. I average 15-16 in town and around 18 on the interstate. Towing milage is probably worse than the 5 liter but holding 6th gear cresting hills makes me grin.
I get about 18 to 20 miles per gallon on the highway with my 5 L in my 2014 super crew 4 x 4.
159115 (A60430)
159115 (A60430)
Champion Vibratory Roller (A60462)
Champion Vibratory...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
UNUSED FUTURE 72PRO-72" MULCHER (A60432)
UNUSED FUTURE...
BUNDLE OF 3'X30' SHEET METAL (A60432)
BUNDLE OF 3'X30'...
