NAA ENGINE TROUBLE
   / NAA ENGINE TROUBLE #41
Could be a gasket or throttle shaft leak, or dirty circuit.
   / NAA ENGINE TROUBLE #42
Im going to list what happened with mine in another post. Mine would run great...then it would be all over the place. I had completely rewired it and thought I had screwed something up. Put in a new coil and condenser....you know what? When I originally took off the distributor....it was in the dark. I had forgotten that I felt a piece go flying...but wasn't sure cause it was in the dark. I figured the new rotor would have everything I needed. Anyway, I rebuild carb three times, tried to enrich/lean as according to procedure, but I couldn't get it to run consistently especially with throttle changes.....went to buy another condenser and points, talked to the local tractor guy about my problem....also had weird brass shavings sitting on dust cover...(Soundguy probably already knows what the problem is). The shavings bewildered him, I told him the rotor seemed "Awfully loose and had a lot of play in it" but he said "you did put the rotor block back on?" I said "the what"....he reaches into a bin and hands me a 2cent clip. Told me that was the problem and to go in peace. Sure enough, there was no block underneath...and by this time the new rotor had cracked and had worn down the contacts on the new diet cap I had put on. Replaced rotor (with block) cap and she purred like a kitten once I tuned the carb. Geez that was a lot of work.
   / NAA ENGINE TROUBLE #43
That 2 cent clip is really about 6 $ ;)
Yep. My clip was missing also. That's what I thought was the problem. Actually it was part of the problem. The main culprit was the condenser.
Put that in and she is running great.
   / NAA ENGINE TROUBLE #45
OH MY GOSH I AM THRILLED! I can't hardly believe I helped diagnose a problem on Tractorbynet.....6 months ago I couldn't even hardly change the oil. With the clip off, I think all the variable firing fried my condenser as well, because after I put the clip on, It ran like 70% better....and I figured I might as well change points and condenser...then it ran great.
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
Informational Lot - Financing (A52748)
Informational Lot...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
Skid steer auger plate (A50322)
Skid steer auger...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2018 BOBCAT T590 SKID STEER (A51246)
2018 BOBCAT T590...
