Modifying a Traffic Light for the man cave
   / Modifying a Traffic Light for the man cave #1
Scotty Dive
Ct
Yanmar 2020D
I have a LED traffic light (Red, Amber, and Green) and I wired it up. Problem is its very bright - if you walk in front of it and look at it you are somewhat blinded. These are sealed LED lights ( I am sure I could open them up if needed) and was wondering if there was a way to dim them a bit. I know LED's are not really changed (dimmed) by reducing the voltage to them. I was thinking of maybe some diffuser film over the lens but that would probably look pretty odd. Incidentally, it looks like the Red and the Amber are white LEDs (I am guessing here) behind a colored lens and the Green are true green LED's behind a clear lens. Any ideas?
   / Modifying a Traffic Light for the man cave #2
I know there are dimmers that work for LED lights, for in a house switch box that is. But I don't know if they work for any LED lights or if the lights have to be made such that they are dimmable.
I was wondering and might experiment with putting a 110v dimmable switch inside the light housing and preseting itnto the right light level and then another regular single pole switch for off and on...
   / Modifying a Traffic Light for the man cave #4
I should add that I'm aware of two types of dimmer switches that work for 110v home LED lights. I wasn't until I installed one and ended up with buzzing lights.
When I looked for "LED lights buzzing" online, I found this article:
Are Your LEDs Buzzing? Here's the Fix...
I had installed the CL type, and the article says they are usually OK, but the ELV type have always cured the buzzing. I haven't tried one yet to see if it will eliminate my buzzing.
A bit of an update.....I had a 110 v dimmable switch that can be used for CFL and LED's. I rough wired it up and it dimmed it maybe 20%. Which is pretty odd in my mind because on a regular household led, it will dim it to almost off.
Still too bright in my opinion.
   / Modifying a Traffic Light for the man cave #6
I know that the signals in actual use have dimmer in the cabinet. Other than that I am lost
   / Modifying a Traffic Light for the man cave #7
I put a dimmer on the LEDs in my living room. The difference was that they were low volt lights running on a transformer, so I put a dimmer on the input voltage to the transformer. Worked fine and I was able to turn them way down.
Another set I used were to bright so I wired them in series to bring down the apparent voltage to each light. You might try this with your traffic lights by wiring the three lights in series instead of parallel.
Also, when you dim an LED it emits the same color of light, just less of it, unlike an incandescent that becomes more yellow with less voltage.
   / Modifying a Traffic Light for the man cave #8
When you open the traffic light cover is there a controller of any kind that sequences the lights. There should be one and if so what is the controller output voltage to the LED's. If its 12-24V you can get a PWM controller to dim them.
PWM Dimming Controller For LED Lights or Ribbon, 12 Volt 8 Amp, Adjustable Brightness Light Switch Dimmer Controller DC12V 8A 96W for Led Strip Light By Zitrades - Wall Dimmer Switches - Amazon.com
I have a 1960's traffic light (made by Crouse-Hinds in Syracuse) in my garage that I restored. Its one of 4 that I've done. I installed lower wattage bulbs and a controller sequencer to step through the lights. Mine's not LED which is a much newer light.
   / Modifying a Traffic Light for the man cave #9
I'm so jealous. I want/need a traffic light in my shop/man cave.
But hey,,,,, I do have this. :)
   / Modifying a Traffic Light for the man cave #10
Hey, You have the barber chair and Bud sign and a fridge. What more could you need. (OK want)
If you really want one check the local flea markets at car shows. Usually someone is selling used traffic lights for $30-75. Pick one up, take it apart, sand blast and repaint, buy a cheap controller sequencer (<$50), reassemble, hang in the cave and plug it in. I had less than $100 in each and sold 3 for double that.
   / Modifying a Traffic Light for the man cave #11
They are probably not made for 120v. See if you can find technical docs from manufacturer. If you find and don't understand post a link and I may be Allee to help or pm me.
Sent from my SAMSUNG-SM-G890A using TractorByNet
They are 110 v and the controller is not in the light itself but the net tells me that they are usually in the pole on street somewhere. I want to purchase a controller that will change the lights on a programmed schedule. So wiring it in series won't work. As I understand it, the dimmer for a led doesn't reduce voltage but reduces the pulses to reduce the brightness. My guess is that there is some criteria that this traffic light be able to display brightly regardless of electrical conditions.
   / Modifying a Traffic Light for the man cave #13
There are several controllers for these LED traffic lights in the link below. None of them will dim the brightness but they are programmable controllers at a reasonable price.
traffic light controller | eBay
   / Modifying a Traffic Light for the man cave #14
Hey, did you know you can actually take naps in a Barber Chair???? ;)
I gotta search for traffic light. That's very cool.
Nice chev. :thumbsup:
   / Modifying a Traffic Light for the man cave #15
Yes, especially when you recline the chair. We have one at work that one of the guys is restoring (old Dentist chair, same thing) I sat on it and reclined and was ready to take a nap.
Chevy is a 49 1 1/2T with 6700 orig. miles.
   / Modifying a Traffic Light for the man cave #16
Very rare. I doubt I've saw more than 3 or 4 in my life.
   / Modifying a Traffic Light for the man cave #17
Sorry I hope I didn't sound presumptuous that you may not understand the tech docs, obviously you do. That's a good point that for safety low or poor power would maintain the same brightness.
I wonder if lighting gels like for stage lights would dim them.
   / Modifying a Traffic Light for the man cave #18
   / Modifying a Traffic Light for the man cave #19
And he has a large pic of ****** shot through the head! The ultimate man-cave accessory!! :thumbsup:
Hand painted on 1/8" steel plate. Already had the bullet hole when I got it.
   / Modifying a Traffic Light for the man cave #20
Richard , what is that mechanism above and behind the table ? Looks like a cylinder on top of it . By the way , hope the back gets better and Happy Holidays .
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59905)
2020 INTERNATIONAL...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
