Insulation for shop ceiling
   / Insulation for shop ceiling #21
If money is tight I think your least cost will be putting up 2x4s two foot on centers then drywall. Of course your going to need the vapor barrier regardless of what material you put up.
I don't think I would put up a lot of insulation, unless you work there 8 hours every day year round. I read one guy talked about putting in 2 feet of insulation. I wouldn't do half that much for occasional use but maybe 6".
But it is something you can add to if your usage increases
   / Insulation for shop ceiling #22
Another option that would save moving your lights and keep you from putting in a ceiling at all would be to get foamed-in-place closed-cell insulation applied to the underside of the roof. Adds a ton of r-value with just a few inches as well as adding strength if you're in a windy spot. The foam is more expensive than the blown-in or fiberglass, but it might even out with the cost of installing a ceiling and insulating that. Of course, you'd have more space to keep warm but man that foam is TIGHT. Drop a ceiling fan in there and move the air around and your 150k heater wouldn't have a problem i don't think.
Just an idea, might not give you the finish you're looking for. Also, you'd probably need to hire out the job as that is a pretty big area and way up the air for one guy with tigerfoam kits.
   / Insulation for shop ceiling #23
30 x 40 seems huge for a workshop. Do you really use it all for workshop?
   / Insulation for shop ceiling #24
K
Agree, I was going to suggest the same thing.
I did price out having it sprayed and they wanted close to $3500 for less than 2"s so I thought that was a lot. I was thinking the lower ceiling would help since I don't have as much space in there to heat and don't use that space for anything.
Basically I use the entire 30x40 but only walk over and flip on the heat about an hour or two before I am going over to work. (today it was about 40 out and had the bldg at 65 in less than 2 hrs) I normally keep my truck in the building but often move it outdoors to work if I need a second full bay. Also store 2 SxS's in there but they are easily moved around depending on what I am doing. Across the back I have my short range archery range so I can shoot when it is too cold out - also helps for tuning bows and such.
So I really do use it all - different ways on different days - today I have the truck sitting outside because I have tarps every which way so I could spray bedliner on a current project.
   / Insulation for shop ceiling #26
What do you consider the "normal" going rate for the metal? I have to look into and it find someone locally that even sells it.
Thanks
I'm sure you have metal suppliers locally. The pole barn builders have to get it somewhere. Menards, Lowes, etc, also have it available. Make sure you ask for liner panel which is cheaper than roofing/siding. It's still 29 gauge but doesn't have the special 40 year exterior coating. When you add in the J-strips for the edges and the fasteners, I usually figure it at about $1 per square foot. Don't forget to plan to frame in an attic access opening.
   / Insulation for shop ceiling #27
3 months ago I bought 26 gauge R-panel for $2.20 per foot for colors and $1.75 per foot for galvanized. Many places wanted as much as $2.85 per foot for the colors.
Thank you!
I may start looking for it tomorrow if all goes as planned.
Anyone have any photos of the metal installed they wouldn't mind sharing?
THANKS
   / Insulation for shop ceiling #30
Definitely look at metal, either R-panels or plain corrugated. The benefit is that it's installed and finished all in one step, with the added benefit of being fire resistant. They sell rolled fiberglass in 3" through 6" thickness and 3' and 6' widths with a vapor barrier.
I have a 30 x 40 metal building that I converted 1/2 of it into an in-law apartment (20 x 30, 600 sq/ft). I used the original weathered corrugated roof metal as the ceiling in the in-law apartment and it looks great.
My metal building was all metal, including metal pipe trusses. I simply welded 2" square tube on the UNDER side of the trusses spaced every 20". This way I avoided having to box around any of the trusses. It was the smartest and most time conserving decision I made when making the in-law apartment. I used 6" blanket insulation over the top.
One thing I did was to put up some angle "trim" around the perimeter. This helped make up for things not being square and my building was grossly unsquare and unlevel. It also allowed me better means for sealing. I shot great stuff foam between the overlap of the trim and the panel and the trim and the wall.
These photos are with me cell, Let me know if you need additional photos or details.
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
2018 Chevrolet Malibu Sedan (A53424)
2018 Chevrolet...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
