E85 for American Fuel Independence !
Status
Not open for further replies.
   / E85 for American Fuel Independence ! #51
Pimentel, David
David Pimentel, PhD at Cornell University wrote the following;
Neither increases in government subsidies to corn-based ethanol fuel nor hikes in the price of petroleum can overcome what one Cornell agricultural scientist calls a fundamental input-yield problem: It takes more energy to make ethanol from grain than the combustion of ethanol produces.
At a time when ethanol-gasoline mixtures (gasohol) are touted as the American answer to fossil fuel shortages by corn producers, food processors and some lawmakers, Cornell's David Pimentel takes a longer range view.
"Abusing our precious croplands to grow corn for an energy-inefficient process that yields low-grade automobile fuel amounts to unsustainable, subsidized food burning," said the Cornell professor in the College of Agriculture and Life Sciences. Pimentel, who chaired a U.S. Department of Energy panel that investigated the energetics, economics and environmental aspects of ethanol production several years ago, subsequently conducted a detailed analysis of the corn-to-car fuel process. His findings will be published next month in the forthcoming Encyclopedia of Physical Sciences and Technology.
Among his findings:
* An acre of U.S. corn yields about 7,110 pounds of corn for processing into 328 gallons of ethanol. But planting, growing and harvesting that much corn requires about 140 gallons of fossil fuels and costs $347 per acre, according to Pimentel's analysis. Thus, even before corn is converted to ethanol, the feedstock costs $1.05 per gallon of ethanol.
* The energy economics get worse at the processing plants, where the grain is crushed and fermented. As many as three distillation steps are needed to separate the 8 percent ethanol from the 92 percent water. Additional treatment and energy are required to produce the 99.8 percent pure ethanol for mixing with gasoline.
* Adding up the energy costs of corn production and its conversion to ethanol, 131,000 Btu are needed to make 1 gallon of ethanol. One gallon of ethanol has an energy value of only 77,000 Btu. "Put another way," Pimentel said, "about 70 percent more energy is required to produce ethanol than the energy that actually is in ethanol. Every time you make 1 gallon of ethanol, there is a net energy loss of 54,000 Btu."
* Ethanol from corn costs about $1.74 per gallon to produce, compared with about 95 cents to produce a gallon of gasoline. "That helps explain why fossil fuels -- not ethanol -- are used to produce ethanol," Pimentel said. "The growers and processors can't afford to burn ethanol to make ethanol. U.S. drivers couldn't afford it either, if it weren't for government subsidies to artificially lower the price."
* Most economic analyses of corn-to-ethanol production overlook the costs of environmental damages, which Pimentel says should add another 23 cents per gallon. "Corn production in the U.S. erodes soil about 12 times faster than the soil can be reformed, and irrigating corn mines groundwater 25 percent faster than the natural recharge rate of ground water. The environmental system in which corn is being produced is being rapidly degraded. Corn should not be considered a renewable resource for ethanol energy production, especially when human food is being converted into ethanol," Pimentel said.
* The approximately $1 billion a year in current federal and state subsidies (mainly to large corporations) for ethanol production are not the only costs to consumers, the Cornell scientist observes. Subsidized corn results in higher prices for meat, milk and eggs because about 70 percent of corn grain is fed to livestock and poultry in the United States. Increasing ethanol production would further inflate corn prices, Pimentel said, noting: "In addition to paying tax dollars for ethanol subsidies, consumers would be paying significantly higher food prices in the marketplace."
Nickels and dimes aside, some drivers still would rather see their cars fueled by farms in the Midwest than by oil wells in the Middle East, Pimentel acknowledges, so he calculated the amount of corn needed to power an automobile:
* The average U.S. automobile, traveling 10,000 miles a year on pure ethanol (not a gasoline-ethanol mix), would need about 852 gallons of the corn-based fuel. This would take 11 acres to grow, based on net ethanol production. This is the same amount of cropland required to feed seven Americans.
* If all the automobiles in the United States were fueled with 100 percent ethanol, a total of about 97 percent of U.S. land area would be needed to grow the corn feedstock. Corn would cover nearly the total land area of the United States.
   / E85 for American Fuel Independence ! #52
Eddie already said it. Ethanol destroys engines. It has to be made, utilizing more energy than it replaces.
Really? My 1974 Pontiac Catalina somehow didn't get the memo from Eddie. The 400 carbureted small block in it went for 250,000 miles getting E10 from the late 70's on thru it's demise in the mid 90's. The motor was still fine, the car succumbed to body cancer.
   / E85 for American Fuel Independence ! #53
Wow! 4.8 billion in agriculture subsidies in one year for the entire U.S. ag sector! That is downright criminal! Especially when it only cost us 14 billion per month during the 10 year Iraq war! What a waste of resources. We could have thrown even more into the Iraq war and provided more stuff for ISIS to get their hands on after we left if we had've taken the 400 million a month that goes to agriculture. How short sighted we are.
Changing the topic does not change that you are wrong in your statements about ethanol. It only proves you are also ignorant about world affairs.
   / E85 for American Fuel Independence ! #54
Prove me wrong. Where did I err in the numbers?
   / E85 for American Fuel Independence ! #55
Pimentel, David
Among his findings:
I appreciate Dr. Pimentel's input in the issue. That is one man's consensus in relation to an entire Argonne National Lab study.
   / E85 for American Fuel Independence ! #56
The most pertinent example given is why isn't ethanol used to create ethanol instead of fossil fuel?
   / E85 for American Fuel Independence ! #57
Then explain why ethanol is traded on the commodity exchange closed at $1.471 and gasoline on the commodities exchange closed at $1.388. If it takes $1.74 per gallon to produce ethanol, that is a net loss of 27 cents a gallon. Now why, pray tell, would anyone produce something at a such a significant loss? Can't be because they are subsidized, as all subsidies for ethanol production came to a close at the end of 2011. Government may control the level of ethanol used in gas, but it doesn't control price, and ethanol is traded like any other commodity on the market. And they can't make anyone produce a product at a loss.
Fossil fuel to make ethanol is in the form of natural gas. The price is ridiculously low for that fuel source. Makes sense to use it for ethanol production.
   / E85 for American Fuel Independence ! #58
A Bit of a wrench in the "40mpg to save us all" scheme. It only takes a couple of generations to double the population. Maybe less. Then what?
ETA Cost of production.
Just for comparison. In 2012, Corn sold for up to $8.00 a bushel. That bushel could yield 2.7 gal. of ethanol
Doing the math.....>2.90 /gal
Now corn is about $4 a bushel with futures to $4.50. A buck and a half per gallon.
NB Those are market prices BEFORE processing to extract ethanol.
How does that work in the "free market"?
   / E85 for American Fuel Independence ! #59
Ethanol fuel should be pumped back into the horse it came from.
Copperhead - You are right on !
Status
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2011 Mercedes Benz Sedan (A51694)
2011 Mercedes Benz...
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2007 Boston Whaler w/ Dual 200HP Mercury OptiMax (A51694)
2007 Boston Whaler...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
Unused 2025 Bale Spear Skid Steer Attachment (A51691)
Unused 2025 Bale...
