hydraulics. any rules of the thumb? do or don'ts?
   / hydraulics. any rules of the thumb? do or don'ts? #11
Don't use plumbing fittings on a hydraulic system.
   / hydraulics. any rules of the thumb? do or don'ts? #12
x2. no black iron or galvanized water fittings.
Beyond that, you are going to have to be more specific. I could write a hundred pages and not be done.
   / hydraulics. any rules of the thumb? do or don'ts? #13
Major rule:
BEWARE of high pressure leaks. When hydraulics penetrate your skin REAL BAD things happen.
   / hydraulics. any rules of the thumb? do or don'ts? #15
Major rule:
Right, and if you suspect a leak, check for leaking fluid with a piece of cardboard, paper or wood, rather than your hand.
   / hydraulics. any rules of the thumb? do or don'ts? #16
There shouldn't be any problem using black pipe fittings on tank return lines or suction lines. The elbows have less restriction than high pressure hydraulic fittings.
   / hydraulics. any rules of the thumb? do or don'ts? #17
Try this video series for a good basic understanding of hydraulics "https://www.youtube.com/watch?v=4szV1K2Chso&index=2&list=PL68FA436463CE454D"
   / hydraulics. any rules of the thumb? do or don'ts? #18
   / hydraulics. any rules of the thumb? do or don'ts? #19
How about this rule, never ever ever work on a system that is under pressure. Just because the machine is off (and it had better be) does not mean the system is not pressurized. A few souls here will show you the pictures of flesh torn from their hands from pressurized oil. And too that, never ever try and find a leak with your hand. A pinhole leak in a hose will punch right out the other side if you are not careful. Pressurized systems are incredibly dangerous (and I am not referring just to Hydraulics).
Rolling Platform (A47809)
Rolling Platform...
2021 Caterpillar 304E2 Mini Excavator (A46683)
2021 Caterpillar...
2008 GENIE S-60 MANLIFT (A47001)
2008 GENIE S-60...
2004 Sterling Acterra 1,000 Gallon Water Truck (A45336)
2004 Sterling...
3pt Ditcher (A47307)
2007 FORD F-450(INOPERABLE) (A47001)
2007 FORD...
