hydraulics. any rules of the thumb? do or don'ts?
   / hydraulics. any rules of the thumb? do or don'ts? #11
Don't use plumbing fittings on a hydraulic system.
   / hydraulics. any rules of the thumb? do or don'ts? #12
x2. no black iron or galvanized water fittings.
Beyond that, you are going to have to be more specific. I could write a hundred pages and not be done.
   / hydraulics. any rules of the thumb? do or don'ts? #13
Major rule:
BEWARE of high pressure leaks. When hydraulics penetrate your skin REAL BAD things happen.
   / hydraulics. any rules of the thumb? do or don'ts? #15
Major rule:
Right, and if you suspect a leak, check for leaking fluid with a piece of cardboard, paper or wood, rather than your hand.
   / hydraulics. any rules of the thumb? do or don'ts? #16
There shouldn't be any problem using black pipe fittings on tank return lines or suction lines. The elbows have less restriction than high pressure hydraulic fittings.
   / hydraulics. any rules of the thumb? do or don'ts? #17
Try this video series for a good basic understanding of hydraulics "https://www.youtube.com/watch?v=4szV1K2Chso&index=2&list=PL68FA436463CE454D"
   / hydraulics. any rules of the thumb? do or don'ts? #18
   / hydraulics. any rules of the thumb? do or don'ts? #19
How about this rule, never ever ever work on a system that is under pressure. Just because the machine is off (and it had better be) does not mean the system is not pressurized. A few souls here will show you the pictures of flesh torn from their hands from pressurized oil. And too that, never ever try and find a leak with your hand. A pinhole leak in a hose will punch right out the other side if you are not careful. Pressurized systems are incredibly dangerous (and I am not referring just to Hydraulics).
Grain Auger w/ Motor (A47809)
Grain Auger w/...
John Deere 2020 Pro Gator (A47307)
John Deere 2020...
2011 TEMPLES TRAILER SALES INC FLARE STACK (A47001)
2011 TEMPLES...
2012 JACK COUNTY  130BBL VACUUM TRAILER (A47001)
2012 JACK COUNTY...
Chain Link Fencing (A47809)
Chain Link Fencing...
2025 Kivel 48in Skid Steer Forks and Frame (A44571)
2025 Kivel 48in...
