Why does everyone rant and rave about the EcoBoost?
   / Why does everyone rant and rave about the EcoBoost? #191
Set the fuel to the desired btu's and the follow with the stack O2 sensor to adjust inlet air.
   / Why does everyone rant and rave about the EcoBoost? #192
Btu's?? We just kept an eye on the pressure gauge and adjusted the rate we was shovelling the coal. Think the air was adjusted as to the looks of the firebox and if we needed more or less pressure. Getting a little clay mixed in really spilled apples.
   / Why does everyone rant and rave about the EcoBoost? #193
I was thinking of the coal feed into the pulverizers and the fuel blowers .
   / Why does everyone rant and rave about the EcoBoost? #194
   / Why does everyone rant and rave about the EcoBoost? #195
Okay, but where is that BTU sensor? When the boss said shovel harder that's what we did until the gauge turned to red.
   / Why does everyone rant and rave about the EcoBoost? #196
The control computers read the RTD's or thermocouples in the stack outlets, saturated steam , super heated steam, high pressure turbine , low pressure turbine , the re-heaters, condensate feed heaters, low pressure turbine discharge temp, condensate water temp and condensor cooling water temp. Stack O2 of course .
Usually send 4-20ma to operate the air dampers, VFD's for the blower and pumps along with the control valves .
   / Why does everyone rant and rave about the EcoBoost? #197
That's a lot of temperature readings. With us the engineer just looked at the pressure gauge and knew the slope of the track coming up and just yelled. Coming on to a hill we was shovelling hard but the downhill side was just loafin around.
   / Why does everyone rant and rave about the EcoBoost? #198
Wuut happened to this thread?
I am surprised the 5.0 has a better payload rating than the ecoboost, yet the ecoboost has the higher towing reasons.
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
