Why does everyone rant and rave about the EcoBoost?
   / Why does everyone rant and rave about the EcoBoost? #171
It has quite a bit to do (or not) with the ecoboost motor. THe ecoboost was not designed to burn ethanol. That is part of the reason to i started this thread, was too see if any one got a 5.0 over the eco-boost for ethanol purposes, or not. IMO if they designed A ecoboost to burn ethanol (especially a 5l or 6.2l ecoboost) that would be champ.
What?! You mean you can't burn EE 85 in An ecoboost motor?
   / Why does everyone rant and rave about the EcoBoost? #172
E85 in the States is a different animal than what we get here. E85 is 85% ethanol, which you cannot even buy up here.
   / Why does everyone rant and rave about the EcoBoost? #174
When I bought my 5.0, I did think of the flex fuel option as a bonus. Not sure why, but figured, hey, it gives me that option if I want use E85.
However, after reading the trucks manual, it turned me off to it somewhat. I already knew the mileage would drop 30% (according to the EPA), but Ford says NOT to use E85 all the time. You need to use E10 (or pure gas) occasionally. You also have to do more frequent oil changes. That tells me it's not the best thing for an engine. But I like it for an annual system cleaning.
   / Why does everyone rant and rave about the EcoBoost? #175
Burning alcohol effiecently require's an engine designed for it. Then it becomes more efficient than a gas engine?
Octane rating of alcohol allows much higher boost or compression or combination of the two.
   / Why does everyone rant and rave about the EcoBoost? #176
You nailed it. My take on this - Ford could build an eco-boost for E85. They could probably make it about a 12:1 compression engine and put a lot of boost on top of that and get at least as much power on E85 as they now get (burning somewhat more gallons of E85). The downside (and reason they don't do it) is that to run regular gas they would have to ****** the ignition and cut the boost way down - making it a dog on gas or E10. The real world has limitations.
(Disclaimer - this is all my opinion - like almost everything else in this thread. :laughing:)
   / Why does everyone rant and rave about the EcoBoost? #177
   / Why does everyone rant and rave about the EcoBoost? #178
Doesn't become more efficient, just makes more power. E85 is extremely tolerant of preignition and detonation. So you can crank the cylinder pressure way up, either with boost or mechanically.
   / Why does everyone rant and rave about the EcoBoost? #179
//And none of this changes the fact that you are hiljacking threads over this issue all over the place on TBN. Please cut it out. Beyond an initial mention you are into shill land, frankly.
44 posts, 40 are about E85.
I suggest he go find some motorcyclists and sing the praises of E85 to them too: I'm sure he'll receive an unforgettable sharing of opinions.....
What do the TOY say about this kind of promotional spamming?
   / Why does everyone rant and rave about the EcoBoost? #180
44 posts, 40 are about E85. I suggest he go find some motorcyclists and sing the praises of E85 to them too: I'm sure he'll receive an unforgettable sharing of opinions..... What do the TOY say about this kind of promotional spamming?
I think you guys are being to harsh on the guy. He has made some valid points. I'm not a fan of ethanol for small engines or vehicles that sit but have no issue running it in my daily drivers.
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
18Ft Rollins Trailers Inc. Steel Trailer (A57453)
18Ft Rollins...
2015 Nissan Frontier Ext. Cab Pickup Truck (A56858)
2015 Nissan...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2025 GPS GT612 S/A 12ft Utility Trailer (A56859)
2025 GPS GT612 S/A...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
