.???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #1
Budweiser John
Dewitt, Michigan
New Holland TC45D
I am making a hand rail for our local church.
I ordered the brackets from King archetual metals and will use 1 1/4" schedule 40 pipe for the rail.
The brackets are malleable iron and my question is:
Should I use a 70 series stick rod, flux core mig wire, or something more exotic? Each weld would be about 2" in length connecting the malleable brackets to the pipe rail.
Thanks members, for any wisdom.
B. John
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #2
Technically you should use a nickel base rod. But I would try some 3/32-inch 7018. Make short welds! Might want to use a little preheat on the brackets also.
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #3
If you have to ask, I wouldn't weld it at all. The welds may not meet structural requirements. I'd use mechanical fasteners. If your welds break, if could make for a bad day for someone.
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #4
I disagree on this. It is a hand rail, likely using insert fittings, not steering parts or a trailer. 7018 will work fine.
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #5
If I remember correctly, by code hand rail is suppose to with stand a 200-pound man falling into it. This is generally where apprentices get their start with welding, and lots of grinding!:laughing:
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #6
If the weld is good 7018 will sure do the job. Grlnding makes the welds look better-not work better. Aprentices best friend.
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #7
Back in my pipefitter days we tried to weld malleable fittings to carbon steel pipe. Malleable iron has a lot of carbon in it and is a few steps above cast iron. Like shield arc said a nickle base rod might work. Never tried it. We found that welding with a carbon steel rod; it brittelized the malleable and it broke apart easy under stress. We resorted to brazing with a nickle bronze rod and regular flux; when in a situation requiring its use. Usually this was a threaded fitting leaking and no good way to disassemble the pieces to remake the joint. There are also bronze based arc rods that work well also.
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #8
Certanium 707
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #9
We powder coat hundreds of feet of both 2 bar and ornamental railing a year that are built by three different fab shops. They are all mig welded with solid core wire.
   / .???? Best rod for welding malleable hand rail brackets to schedule 40 black pipe #10
Have you asked King architectural metals?
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2022 BOBCAT MT100 STAND-ON SKID STEER (A60429)
2022 BOBCAT MT100...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
