Need 220vAC electrical help - change 4 prong outlet to 3-prong
   / Need 220vAC electrical help - change 4 prong outlet to 3-prong #51
All this advice flies out the window when wiring up a 50 amp 4 prong service for a camper. Many an electrician has fried camper internals when wiring them up as a 240V system. The are supplied with two 50 amp 110V circuits when properly wired but they look like 220 volt 4 prong plugs.
If you plan to run your camper off a generator with 220v power DONT DO IT. There are lots of YouTube videos on how to correctly wire up a RV plug.
50 AMP service is 240v in an RV. It is the 30 AMP service which is 120v that gets mis-wired to 240v
   / Need 220vAC electrical help - change 4 prong outlet to 3-prong #54
Sometimes it only fries microwaves. Don't ask how I know.
i don't know what this even means, there is nothing different between residential 50amp 240 and rv 50amp 240. if your saying your micro got fried, you had a problem, either a loose neutral or something else.
   / Need 220vAC electrical help - change 4 prong outlet to 3-prong #55
No, I meant that a close friend wired a 30 amp camper plug to 220 breaker panel not considering it was a 120 volt plug. They look like 220 plugs but are actual 110. Has nothing to do with 4 wire. He turned on his microwave and burnt the control panel in the microwave.
   / Need 220vAC electrical help - change 4 prong outlet to 3-prong #56
Ok, I am going to attempt to make things "clear as mud" regarding tying Neutral to Ground at the far end of a generator or electrical panel. I realize that 99%+ of everyone has very limited formal electricity or electronics training or background, but here goes.
The reason many of you are still alive today is that before the NEC was changed to requiring 4 wires (hot, hot, neutral & ground) you may have received slight electrical shocks when touching the case of an electrical appliance. The primary reason you are not dead now is that the electrical shock was very very dependent on how much current (amperage) was flowing on the (safety ground) AND how long a wire was required to go back to the electrical panel AND the wire gauge (electrical resistance) of the wire that went back to the electrical panel. All 3 factors determined if you got a very slight shock, a mild shock, a strong shock or you died.
* If the wire to the electrical panel was very short and, (let's say), 12AWG, then you may have received a very slight shock.
* If the wire to the electrical panel was very long and, (let's say), it was 14AWG, plus a 100ft+ extension cord, then you may have received a mild to strong shock.
* If you used several 100ft lengths of (let's say) 16AWG extension cords and the AC outlet was another 150ft of 14AWG wire from your electric panel (or generator), then you are probably not around any more to read why you died.
For those of you that have no thorough understanding of electricity, or amperage, or electrical resistance or voltage or wire length, then, you were fortunate that the NEC was changed to let you live a little longer.
Don't be stupid. I know many of you are saying, "Hey, it works, therefore it must be OK". Pay attention to some of the people in this post that are just trying to provide a little education and keep you alive. We do not expect you to fully understand all of the technical reasons, but just remember the next time you get shocked, you might be dead and not here to post a response that says "Yep, I was stupid and ignored the warnings."
I hate to be morbid, but wake up and realize that just because "it works" does not mean it is safe. You (or someone in your family) can be seriously injured or die from incorrect wiring practices and it is possible that you could also be sued by your incorrect wiring practices if someone else gets injured.
Wire it the way you want. I hope you live long and prosper by taking some of our advice.
   / Need 220vAC electrical help - change 4 prong outlet to 3-prong #57
OK, here's what I learned and have implemented for using my Honda EU6500IS:
The manual states that the frame is NOT grounded. The frame has a ground lug to be connected to Terra Firma with a cable and a spike at least 2' into the earth.
You can test to see if a/the generator is grounded by checking the resistance between the ground slot and the neutral slot (the one on the left as you face it) on the 110v receptacle on the generator with a meter. If they are connected the resistance will be zero.
Connecting the 'four prong plug' to a 3 prong RV cable takes a special prong plug (available from Honda or others) that engages only one side of the 220 outlet, the neutral, and the green ground slot. Thus, one of the pins will be missing. This plug looks like a standard 4 prong twistlock plug but only has 3 prongs and uses only one of the 110v pins for the 220 generator outlet to provide 30 amps at 110v to an RV.
"Grounds" only carry "fault" currents. These fault currents usually occur in the generator head because a winding leak forms from age, overload, mice or cheap parts.
"Neutrals" are designed to carry currents as per normal operation.
Neutral is white as a standard.
Ground is green as a standard.
Black and red are usually the +110 and -110 current lines.
If it is necessary to ground the generator to neutral for 110v operation, you can buy or make a plug for one of your generator's 110v outlets that ties the bottom (round) pin to the wider left side neutral.
My Winpower 50kw 220v pto generator has only a 3 slotted range receptacle for connectivity. The plug shows neutral and the two 110v hot lines.
Resurrecting this thread because I have to run a 3wire 240v compressor off my Generator. I can buy all the plugs etc and make ay-dapters, but that stuff is hours away. I wanna use what I have on hand.... which is put this 4-wire plug on a 3 wires cord, plug it in, and compress air ----->Now.
473745d1467756295-need-220vac-electrical-help-change-bond-xy-jpg
SO....... Green wire is in G, White wire is in W.
I suppose to bond it within the plug - I simply choose X or Y for the black, and jumper across from X to Y? It can't be any other way, but just wanna check first. Sometimes just a little delay is best.
   / Need 220vAC electrical help - change 4 prong outlet to 3-prong #59
No. Don't bond. Omit. You've got to have red/black opposite of each other. Looks like you have the red hot in the neutral position. Red and black should be next to green. Neutral would not be used for a 240V compressor. If you were running to 120V circuits then you'd need neutral I suppose, but not if the compressor is 240.
No. Don't bond. Omit. You've got to have red/black opposite of each other. Looks like you have the red hot in the neutral position. Red and black should be next to green. Neutral would not be used.
OK thanks. The wire colors are White Black Green. The "white" wire is faded (to look like red in the pic).
SO.... What you are saying is ---- black and white (the two hot legs) must be across/opposite each other? If thats the case then GWXY does not help me. What if you look at the prong end of the plug? What is the prong with the "hook"? If that is either neutral or ground, then across is the "other" cross pair. So my hots go on the OTHER two prongs. Is this right?
*Selling at Royal Auction Zephyrhills, FL Location* 5 (A59228)
*Selling at Royal...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56438)
2008 Ford F-250...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
