Don't know how some of you get the usage so low?
All gas appliances?
I average 1000 kwh at my small 1300sq ft house. All led and wood heat.
Another 300-400 kwh at the shop. And am only down there a few days a week
I have tracked our power usage since we moved into the house since I designed what should be an energy efficient home and I wanted to see if the designer was a dummy or got the design right. :laughing::laughing::laughing:
The house is 2425 sf with 10 foot ceilings which help the comfort level in the summer but not so much in the winter. Take your design priority and move on.
We have more than the code recommended insulation in the attic and the walls are R19 2x6 walls with 1" rigid insulation. However, we have lots of big windows and doors, so the R19 wall might not have been a wise use of money given the energy holes, aka windows and doors.
We wanted to see the place so we think it was a good design choice but it surely costs us some heating/cooling money and maybe a bit of comfort.
Our average monthly power usage is 1247 KWH. The highest being 1336 KWH and the lowest 1164 KWH. Only a difference of 13%, and for most years, the KWH usage is remarkably close year to year.
After heating and cooling, hot water generation is supposed to be a big energy cost, but I suspect in our case it is laundry. We have two kids so the washer, and worse, the dryer is constantly running, ie, spending money.
Cooling the house is our biggest power usage, followed I would guess laundry and then heating water. Heating the house can be expensive if we run out of wood, or ironically like this year, when it is warmer than normal when we don't start the fire since it is too warm but chilly enough where we need to heat the house a bit. We have 85ish ceiling cans which have always used CFLs. Our power bill would be much higher if we did not use CFLs. The price of LED is getting close to the point were we will use them instead of CFLs so that should help our power usage a bit.
The house we lived in back in the city was built in the mid 70's, had minimal insulation compared to today's standards AND had metal windows.
We were always cold in that house but cooling in the summer was not bad because the house was shaded by big pine trees. The city house was half the size of our current house but used the same amount of power at best. I suspect if we were comparing apples to apples the old house used 25-50% more KWH than our larger house. The diminished power usage in our "new" house is due to insulation, build quality and design.
Later,
Dan
