Today's new cars are way overpowered...
   / Today's new cars are way overpowered... #231
In all conditions....
Forgot to add: back in the mid 1980's I had a Zuzuki. This was when few vehicles had four wheel drive. On the icy street light stops it always made it across the intersection first. Could be quite amusing at times.
   / Today's new cars are way overpowered... #232
The nice thing about the 700R is it doesn't require a computer, so it gives you a quick launching 1st gear and a nice overdrive to drop the RPMS for cruising in an older car. Today, if you're going to go to the trouble of putting in a modern engine like an LS with electronic fuel injection, you may as well go with a modern transmission too.
What ever happened to the 413 ahead of a 747 ?
   / Today's new cars are way overpowered... #233
Last winter I had one of our Cruze Turbodiesels with newly-mounted winter tires. We got an early AM snowstorm so the first commuters just packed it down and turned it into ice. Traffic was a horror show.
Got off Rt 93 onto Rt 28 in NH. At the next light a Cadillac Escalade and an F250 both nailed it on the green light and started spinning their wheels: the finest "no-season" tires at work.
At the next light where there was three lanes I pulled up next to them, and just drove away without even spinning a tire [General Altimax Arctic]. Never understood why people spend $50,000 on a truck and use lousy tires.
   / Today's new cars are way overpowered... #234
I agree. A set of snows is cheaper than a deductible and your lost time even from just a fender bender in most cases...
Aaron Z
   / Today's new cars are way overpowered... #235
I would go with a 2 speed power glide. You should be able to get a good one for a weekend street/strip tire smoker without breaking the bank.
   / Today's new cars are way overpowered... #236
A 700R will launch faster and be so much more streetable because of the overdrive. Compare the gear ratios.
453077d1452300249-todays-new-cars-way-overpowered-transmission-ratios-jpg
   / Today's new cars are way overpowered... #237
The 700R4 and it's improved electronic offspring such as the 4L60-65-70E's are great transmissions. But a lot of racers and street guys like that the "200 4 R" still has a low first gear and has closer ratios that work well with smaller engines that have smaller power curves. Having said that, the Electronic controlled 4L series are my favorites.
A good 2004R build link...TH2004R Transmission Build - How To Strengthen A Chevy Turbo 200 - Super Chevy Magazine
   / Today's new cars are way overpowered... #238
Good read. Thanks! :thumbsup:
The 200 appears to be the same length as the 350-400, so that would be a plus in a transplant. The 700 is longer. I like the launch from my 700/4L60E's. I usually don't get past the shift to second point comparison much in town! :laughing:
   / Today's new cars are way overpowered... #239
Well, We are talking two different directions as I wouldn't be concerned with a overdrive. As far as a hard launch, I would be more concerned with my convertor (and few other things) than my first gear ratio.
   / Today's new cars are way overpowered... #240
That gear ratio chart is quite interesting. It made me look up my gear ratios which are:
R-Spec / Ultimate model
Gear ratios :)1) 8AT
1st 3.964
2nd 2.468
3rd 1.610
4th 1.176
5th 1.000
6th 0.832
7th 0.652
8th 0.565
Reverse 2.273
Final gear ratio 3.909
This gives me a big advantage over higher hp cars with 4 speeds in the 1/4 mile.
2006 GMC C8500 Altec DM47 47ft Digger Derrick Truck (A55852)
2006 GMC C8500...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A55973)
2013 Chevrolet...
