Today's new cars are way overpowered...
   / Today's new cars are way overpowered... #231
In all conditions....
Forgot to add: back in the mid 1980's I had a Zuzuki. This was when few vehicles had four wheel drive. On the icy street light stops it always made it across the intersection first. Could be quite amusing at times.
   / Today's new cars are way overpowered... #232
The nice thing about the 700R is it doesn't require a computer, so it gives you a quick launching 1st gear and a nice overdrive to drop the RPMS for cruising in an older car. Today, if you're going to go to the trouble of putting in a modern engine like an LS with electronic fuel injection, you may as well go with a modern transmission too.
What ever happened to the 413 ahead of a 747 ?
   / Today's new cars are way overpowered... #233
Last winter I had one of our Cruze Turbodiesels with newly-mounted winter tires. We got an early AM snowstorm so the first commuters just packed it down and turned it into ice. Traffic was a horror show.
Got off Rt 93 onto Rt 28 in NH. At the next light a Cadillac Escalade and an F250 both nailed it on the green light and started spinning their wheels: the finest "no-season" tires at work.
At the next light where there was three lanes I pulled up next to them, and just drove away without even spinning a tire [General Altimax Arctic]. Never understood why people spend $50,000 on a truck and use lousy tires.
   / Today's new cars are way overpowered... #234
I agree. A set of snows is cheaper than a deductible and your lost time even from just a fender bender in most cases...
Aaron Z
   / Today's new cars are way overpowered... #235
I would go with a 2 speed power glide. You should be able to get a good one for a weekend street/strip tire smoker without breaking the bank.
   / Today's new cars are way overpowered... #236
A 700R will launch faster and be so much more streetable because of the overdrive. Compare the gear ratios.
453077d1452300249-todays-new-cars-way-overpowered-transmission-ratios-jpg
   / Today's new cars are way overpowered... #237
The 700R4 and it's improved electronic offspring such as the 4L60-65-70E's are great transmissions. But a lot of racers and street guys like that the "200 4 R" still has a low first gear and has closer ratios that work well with smaller engines that have smaller power curves. Having said that, the Electronic controlled 4L series are my favorites.
A good 2004R build link...TH2004R Transmission Build - How To Strengthen A Chevy Turbo 200 - Super Chevy Magazine
   / Today's new cars are way overpowered... #238
Good read. Thanks! :thumbsup:
The 200 appears to be the same length as the 350-400, so that would be a plus in a transplant. The 700 is longer. I like the launch from my 700/4L60E's. I usually don't get past the shift to second point comparison much in town! :laughing:
   / Today's new cars are way overpowered... #239
Well, We are talking two different directions as I wouldn't be concerned with a overdrive. As far as a hard launch, I would be more concerned with my convertor (and few other things) than my first gear ratio.
   / Today's new cars are way overpowered... #240
That gear ratio chart is quite interesting. It made me look up my gear ratios which are:
R-Spec / Ultimate model
Gear ratios :)1) 8AT
1st 3.964
2nd 2.468
3rd 1.610
4th 1.176
5th 1.000
6th 0.832
7th 0.652
8th 0.565
Reverse 2.273
Final gear ratio 3.909
This gives me a big advantage over higher hp cars with 4 speeds in the 1/4 mile.
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
UNUSED IRANCH WROUGHT IRON SITE FENCE (A57193)
UNUSED IRANCH...
2021 Versatile 405 Tractor (A53485)
2021 Versatile 405...
148in Roll Up Garage Door (A55852)
148in Roll Up...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A53421)
2018 Bobcat T590...
